Theory of Structured illumination microscopy
In summary, the conversation discussed the theory behind super resolution microscopy and how it uses a frequency shift to capture information outside of the observable region. The method is based on the interference of light and the formation of moire patterns, which are caused by the interaction between the incident light and the emitted light. Although there are explanations for the process, some people still have a hard time visualizing it. Links to resources and Gustafsson's paper were shared for further understanding.
u0362565
52
Hi all,
My question concerns the theory of how super resolution microscopy causes a frequency shift to allow information normally outside of the observable region of frequency space to be captured by the objective lens.
I have read various papers on this including those by Mats Gustafsson which describe the theory but I'm still having a hard time trying to visualise what's actually going on.
I'd like to be able to describe to people who know nothing about optics how this method works and the angle i'd like to take is that its based on the interference of light. But for my own understanding i'd like to know why moire patterns form when the excitation light is "structured" i.e. contains a high spatial frequency illumination pattern.
When trying to visualise this, a striped pattern would be seen on the sample as regular repeating lines. In the light bands excitation light is exciting the sample but where there is a dark band there is no excitation?
But what i don't really understand is where is the interference coming from? Why is it not simply that there is emission from the light areas of the grid but none from the dark areas.
Its easy to explain beat frequencies in terms of sound and as i understand it beat frequencies in sound and moire patterns are the same thing? When 2 sounds of similar frequency interfere the result is the difference between the 2 frequencies. When thinking of light and structured illumination though its not such a simple case. As the frequencies we're referring to are not the frequencies of light as we traditionally think of it i.e. wavelengths per second, but the spatial frequency of the illumination pattern?
Everything i read talks about the interaction of a high spatial frequency introduced by the incident excitation light and the high spatial frequencies inherent in the distribution density of fluorescence, but to me this isn't a good enough explanation for what's going on. Can anyone explain this in a straightforward way by describing what's actually happening between the incident light and the emitted light to cause moire patterns and thus a frequency shift? Perhaps by replicating the idea of how this occurs with sound.
Thanks for your help!
Matt
I didn't know that such a thing exists. Thanks for posting this. I'm interested in seeing the results.
I like gustafsson's explanation and this paper has the clearest description I've seen. I still feel though that it doesn't explicitly explain why the moire patterns form. Simply saying frequencies mix to produce the difference frequency doesn't seem like enough or should i just accept this as is.
Hello Matt,
The theory of structured illumination microscopy is based on the principle of interference, which occurs when two or more waves of light overlap and combine. In this case, the incident excitation light is structured with a high spatial frequency pattern, meaning that the light waves are arranged in a specific pattern with high spatial frequency. This pattern is then projected onto the sample, where it interacts with the sample's fluorescence. The fluorescence from the sample also has its own inherent spatial frequency, which can be thought of as the pattern of emission from the sample.
When the two patterns (excitation light and fluorescence) overlap, they interfere with each other. This interference results in the formation of moire patterns, which are a visual representation of the combined patterns. The moire patterns contain information from both the excitation light and the fluorescence, allowing for the visualization of structures that would normally be outside the observable range.
To better understand this, you can think of it in terms of sound. Just as the combination of two sound waves with similar frequencies can result in a beat frequency, the combination of two light patterns with different spatial frequencies can result in a moire pattern. In this case, the beat frequency is not audible, but rather visualized as the moire pattern.
I hope this helps to clarify the theory of structured illumination microscopy for you. It is a complex concept, but understanding the principles of interference and how they apply to light can help to visualize and explain the process. Keep exploring and asking questions!
Best,
Related to Theory of Structured illumination microscopy
1. What is the Theory of Structured Illumination Microscopy?
The Theory of Structured Illumination Microscopy (SIM) is a super-resolution imaging technique that uses patterned light to improve the resolution of traditional fluorescence microscopy. This technique involves illuminating a sample with a series of patterns and using computational algorithms to reconstruct a higher resolution image.
2. How does Structured Illumination Microscopy work?
In Structured Illumination Microscopy, the sample is illuminated with a series of patterns, typically sinusoidal or grid-like in nature. These patterns are then shifted and rotated to capture multiple images of the sample. Computational algorithms then use this information to reconstruct a higher resolution image with an improved spatial frequency.
3. What are the advantages of using Structured Illumination Microscopy?
Structured Illumination Microscopy has several advantages over traditional fluorescence microscopy techniques. It can improve the resolution of images up to two times, allowing for better visualization of subcellular structures. It also reduces photobleaching and phototoxicity, making it suitable for live-cell imaging. Additionally, SIM is a relatively simple and cost-effective technique compared to other super-resolution methods.
4. What types of samples are best suited for Structured Illumination Microscopy?
Structured Illumination Microscopy is best suited for biological samples, particularly those with thin, flat morphology such as adherent cells or tissue slices. It is also suitable for imaging structures that are smaller than the diffraction limit of conventional microscopy, such as cell organelles and molecular complexes.
5. Are there any limitations to using Structured Illumination Microscopy?
While Structured Illumination Microscopy can improve the resolution of images, it is still limited by the diffraction limit of light. This technique also requires specialized hardware and software, which may not be accessible to all researchers. Additionally, the use of patterned light can cause artifacts in the final image, which may need to be carefully corrected during analysis.
  • Atomic and Condensed Matter
