[Theory] What's the initial velocity of this falling object?
In summary: I may have been unclear about what I meant by the initial velocity. The initial velocity of the object relative to the ground is not the same as the air balloon's velocity.
Kanyka
Member warned to use the formatting template
So if you have an object in a hot air balloon that it traveling upwards at constant velocity, and this object falls out of the hot air balloon, is its initial velocity 0 or is it the same as that of the balloon?
Thanks in advance!
Likes Wasay
I think this question is based on refrence point.As with respect to hot air balloon the body is at rest with intitial velocity then being equal to zero,while if you consider Earth as refrence point then the object has some initial velocity which is equal to that of balloon given that refrence is earth.
When the problem states that a hot air balloon is "travelling upwards at constant velocity", that already tells you that the default reference frame in use is not that of the hot air balloon. The natural assumption is that the default frame is one in which the ground is at rest.
We need to wait for the original poster to tell us what he thinks about the initial velocity of the dropped object relative to the ground.
Likes Wasay
Thanks in advance!
Initial velocity relative to what? A key point to this question is that "velocity" can only be given relative to some zero point. The velocity of the object relative to the balloon and the velocity of the object relative to the ground are two different values.
I strongly agree that this question is only answerable through the observer's point of view.
Let's say that the situation you speak of only takes into account the moment the object falls. In this case, the object's initial velocity from the point at which it is dropped is zero. In summary, this is because the observer knew nothing before the instance of the object's descent from the air balloon. And if we do take into account the object's velocity from the moment the hot air balloon begins to ascend, then the initial velocity of the object is the same value as the air balloon's velocity. In summary, this is because the observer knew that that object was traveling at a velocity parallel to the air balloon from the very moment he or she observed it.
Ultimately, the initial velocity of the object seems to be dependent upon the parameters of the observer's frame of reference.
Do not invent difficulties that you do not have to.
If the problem tells you that the balloon has an upward velocity then the balloon has an upward velocity. If you can find a frame where this is not true then that is not the frame of reference implied by the problem. It does not matter what inertial frame of reference you assume that the problem is using. It does not even matter whether that frame is inertial. The balloon is moving upward in that frame because the problem specifies that it is doing so.
No. That is incorrect.
Yah you are right sir
My apologies. And looking back at my post, I now see the difficulties you speak of.
Okay, I wrongly assumed that we were talking about specific frames of reference.
Related to [Theory] What's the initial velocity of this falling object?
1. What is the initial velocity of the falling object?
The initial velocity of a falling object is the velocity at which the object starts its descent. It is usually denoted as 'u' in equations and is measured in meters per second (m/s).
2. How is the initial velocity of a falling object calculated?
The initial velocity of a falling object can be calculated using the equation: u = (v - at), where v is the final velocity, a is the acceleration due to gravity (9.8 m/s²), and t is the time in seconds.
3. Does the initial velocity of a falling object affect its final velocity?
Yes, the initial velocity of a falling object does affect its final velocity. A higher initial velocity will result in a higher final velocity, while a lower initial velocity will result in a lower final velocity.
4. Does the weight of an object affect its initial velocity when falling?
No, the weight of an object does not affect its initial velocity when falling. The initial velocity is only affected by the object's mass and the force of gravity acting on it.
5. Can the initial velocity of a falling object change?
Yes, the initial velocity of a falling object can change if there are external forces acting on it, such as air resistance or a change in gravitational force. However, in a vacuum or in the absence of other external forces, the initial velocity will remain constant.
