Therefore, the integer X that satisfies the given inequality is 1.
  • MHB
  • Thread starter veronica1999
  • Tags
    Integer
In summary: The lhs is also bigger than $\frac{1}{100}$ as you can easily check. Hence, $0.01<\frac{100!}{2^{100}(50!)^2}<\frac{1}{10}$.In summary, the integer $x$ that satisfies the given inequality is not unique and can vary depending on the approach taken. However, using specific calculations and approximations, it can be shown that the value of $x$ is in the range of $-1 < x < 0$.
veronica1999
61
What is the integer X which satisfies
10^x < 1/2 X 3/4 X 5/6 X 7/8 X ... X 99/100 < 10^(x+1) ?
Could I get some help?
This contest allows the use of calculators but I still can't think of the right approach.
Mathematics news on Phys.org
Hi Veronica,
This "contest" question is from a previous contest, correct? If it's for an ongoing one we can't help you. Just want to be sure!
Jameson
Jameson said:
Hi Veronica,
Jameson
I think it's from 10 years ago.:)
I am not sure if this will help but what I can think of is to write the middle term as a product.
The top terms are odd so $2n - 1$ and the bottom terms are even so $2n$
Then you have $10^x<\prod\limits_{n=1}^{50}\left(1-\frac{1}{2n}\right)<10^{x+1}$
You can see if that made it any easier.
Hi veronica1999, :)
\begin{eqnarray}
\frac{1}{2}\times\frac{3}{4}\times\ldots\times \frac{99}{100}&=&\frac{1.2.3.4\cdots99.100}{(2.4.6\cdots.100)^2}\\
&=&\frac{100!}{[2^{50}(1.2.3.\cdots.50)]^2}\\
&=&\frac{100!}{2^{100}(50!)^2}\\
\end{eqnarray}
Assuming that you have a very powerful calculator, :) (The maximum factorial expression that can be computed in my one is about \(70!\))
\[\frac{1}{2}\times\frac{3}{4}\times\ldots\times \frac{99}{100}=\frac{100!}{2^{100}(50!)^2}\approx 0.079589\]
Now you should be able to choose a suitable value for \(x\). :)
Kind Regards,
Sudharaka.
veronica1999 said:
What is the integer $x$ which satisfies $$10^x < \frac12 \times \frac34 \times \frac56 \times 7frac78 \times \cdots \times \frac{99}{100} < 10^{x+1}\ ?$$
You want to show that $$\frac1{100} < \frac12 \times \frac34 \times \frac56 \times \frac78 \times \cdots \times \frac{99}{100} < \frac1{10}.$$
One of those inequalities is quite easy. If you shift the numerator of each fraction one place to the left then you get $$\frac12 \times \frac34 \times \frac56 \times \frac78 \times \cdots \times \frac{99}{100} = \frac1{100}\Bigl(\frac32 \times \frac54 \times \frac76 \times \frac98 \times \cdots \times \frac{99}{98}\Bigr) >\frac1{100}$$ (because each fraction in the bracket is greater than 1).
The other inequality seem much less accessible. You can start by calculating the product of the first few fractions, to get $$\frac12 \times \frac34 \times \frac56 \times \frac78 \times \frac9{10} \approx 0.2460937.$$ But that process soon begins to get tedious. You can shorten it to get something mangeable on even a basic calculator, as follows. Group the next five terms together to form an estimate of their product in this way: $$\frac{11}{12} \times \frac{13}{14} \times \frac{15}{16} \times \frac{17}{18} \times \frac{19}{20} < \Bigl(\frac{19}{20}\Bigr)^5 \approx 0.7737809.$$
Similar calculations for the remaining batches of five fractions (those with denominators 22 to 30, 32 to 40, and so on) show that their products are less than 0.8440802, 0.8810956 and so on – you do the remaining ones. Finally, multiplying all these estimates together, you can conclude that the product of all fifty fractions is less than 0.1.
Messy, but it works. I don't see any simpler way of doing the computation.
One way to prove $\frac{100!}{2^{100}(50!)^2}<\frac{1}{10}$ is using Stirling's approximation, which says $$\sqrt{2\pi}\ n^{n+1/2}e^{-n} \le n! \le e\ n^{n+1/2}e^{-n}.$$ Therefore,
\begin{aligned}
\frac{100!}{2^{100}(50!)^2}\le &
\frac{e\cdot100^{100+1/2}e^{-100}}{2^{100}\left(\sqrt{2\pi}50^{50+1/2}e^{-50}\right)^2} =\\
&\frac{e\cdot100^{100}10e^{-100}}{2^{100}2\pi\cdot50^{100}50e^{-100}}= \\
&\frac{10e}{100\pi}=\frac{e}{\pi}\frac{1}{10}< \frac{1}{10}
\end{aligned}
FAQ: Therefore, the integer X that satisfies the given inequality is 1.
What is an integer?
An integer is a whole number that can be positive, negative, or zero. It does not include fractions or decimals.
How do you find the value of 10^x?
To find the value of 10^x, you can use a calculator or you can use the rule that states 10^x is equal to 1 followed by x number of zeros. For example, 10^3 is equal to 1 followed by 3 zeros, which is 1000.
Can x be any number in 10^x?
Yes, x can be any number in 10^x. This includes positive and negative integers, as well as zero. However, keep in mind that the value of 10^x will change depending on the value of x.
What is the significance of 10^x?
10^x is often used in scientific notation, where x represents the exponent and 10 represents the base. It is a way to write very large or very small numbers in a more compact form. It is also commonly used in math and science to represent powers of 10.
How is finding the integer x for 10^x useful?
Finding the integer x for 10^x can be useful in a variety of applications, such as calculating large or small quantities, representing numbers in scientific notation, and solving equations involving powers of 10. It is also useful in understanding the concept of exponents and how they relate to the base 10.
