Thermal Conductance Through Two Materials
In summary, the conversation discussed a thermal conductance homework problem involving heat flow through two materials, gold and silver, of the same length and cross sectional area. It was mentioned that under steady state conditions, the conductance through both materials would be the same. This is because although the temperature gradient may be different due to the difference in conductivity, the power transmitted must be the same in order to follow the principles of energy conservation. Additionally, the concept of steady state means that there is a constant flow of energy through the materials, assuming no power loss through the sides.
XianForce
I had a thermal conductance homework problem where heat flowed through gold, and then silver. Both materials were of the same length and same cross sectional area. The problem mentioned that the energy transfer had reached a steady state, and I found through doing the problem that under these conditions, conductance would be the same through both materials.
Can anyone explain why this is? I thought that the conductivity of the material would still play a role in the rate of energy transfer.
Science news on Phys.org
It does.
The power transmitted is the same (this follows from energy conservation and the requirement of steady state), but as the conductivity is different the temperature gradient is different.
mfb said:
It does.
Yes, I understand the second part, but why would the power be the same through both? What about something being in "steady state" makes that happen?
Imagine 100 W of heat transferred from one side to the center and 200 W transferred from the center to the other side. You now have a device which produces 100 W thermal power out of nowhere and violates energy conservation.
By definition...steady state means steady temperatures and therefore steady rate of flow of energy. Ie constant power Through the materials , assuming no power loss through the sides.
Related to Thermal Conductance Through Two Materials
1. What is thermal conductance?
Thermal conductance is a measure of the rate at which heat flows through a material or between two materials. It is the reciprocal of thermal resistance and is typically measured in watts per Kelvin.
2. How is thermal conductance through two materials calculated?
The thermal conductance through two materials can be calculated by dividing the temperature difference between the two materials by the total thermal resistance of the system. This can be determined by considering the individual thermal resistances of each material and any interfaces or contact resistances between them.
3. What factors affect thermal conductance through two materials?
The thermal conductance through two materials is affected by several factors including the thermal properties of the materials (such as thermal conductivity and specific heat capacity), the thickness and surface area of the materials, and the presence of any interfaces or contact resistances.
4. How does the interface between two materials affect thermal conductance?
The interface between two materials can significantly affect the thermal conductance between them. A poor interface, such as an air gap or layer of insulation, can create a thermal barrier and decrease the overall conductance. On the other hand, a good interface, such as a thermal paste or direct contact between the materials, can improve the thermal conductance.
5. How can thermal conductance through two materials be improved?
To improve thermal conductance through two materials, one can use materials with higher thermal conductivity, increase the surface area of contact between the materials, reduce the thickness of the materials, and use thermal interface materials or techniques to improve the interface between the materials. Additionally, improving the overall thermal design of the system can also help to improve thermal conductance.
