Thermal Conductivity in Supercritical Fluids
In summary: This is due to the unique properties of supercritical fluids, such as their high density and high heat capacity, which can affect thermal conductivity. Therefore, in summary, the thermal conductivity of a liquefied gas usually increases when it becomes a supercritical fluid, and the relation between molecular mass and thermal conductivity is generally similar, but can be more pronounced, compared to the gaseous phase.
Kasper_NYC
Hi there,
Please, I would like to know if the Thermal Conductivity of a liquefied gas increases or decreases when becomes a supercritical fluid.
Also, I would like to know how is the relation between the molecular mass and thermal conductivity of a liquefied gas and a supercritical fluid, because in the gaseous phase, as higher the molecular mass, smaller seems to be the thermal conductivity value. Per example in gaseous phase:
Helium
Molecular weight : 4.0026 g/mol
Thermal conductivity (1.013 bar and 0 °C (32 °F)) : 142.64 mW/(m.K)
Methane
Molecular weight : 16.043 g/mol
Thermal conductivity (1.013 bar and 0 °C (32 °F)) : 32.81mW/(m.K)
Hexafluoroethane - R116
Molecular weight : 138.02 g/mol
Thermal conductivity (1.013 bar and 0 °C (32 °F)) : 13.47mW/(m.K)
Is it the same for supercritical fluids?
http://en.wikipedia.org/wiki/Supercritical_fluid
Thanks a lot.
PS - This is not a homework question, is part of a personal and independent research. I hardly tried to find the answer, but I could not. I did not ask about it in the Chemical Forum because I consider it not a formulation problem, but a question about the characteristics of the state of the matter. Thanks.
Science news on Phys.org
The thermal conductivity of supercritical fluids usually increases with increasing temperature, pressure, and molecular mass. Generally, the thermal conductivity of a supercritical fluid is greater than that of its gaseous and liquid phases. The relation between molecular mass and thermal conductivity of a supercritical fluid is generally similar to that of its gaseous phase, in that higher molecular mass will generally result in lower thermal conductivity. However, the magnitude of the difference in thermal conductivity between different molecules can be more pronounced for supercritical fluids than for their gaseous phase.
Related to Thermal Conductivity in Supercritical Fluids
1. What is thermal conductivity in supercritical fluids?
Thermal conductivity in supercritical fluids refers to the ability of a supercritical fluid to transfer heat from one point to another. It is a measure of the rate at which heat is conducted through the fluid and is influenced by the fluid's properties such as temperature, pressure, and density.
2. How does thermal conductivity in supercritical fluids differ from that in regular fluids?
Thermal conductivity in supercritical fluids is significantly higher than that in regular fluids. This is due to the unique properties of supercritical fluids, such as their high density and low viscosity, which allow for more efficient heat transfer.
3. What factors affect the thermal conductivity of supercritical fluids?
The thermal conductivity of supercritical fluids is influenced by several factors, including temperature, pressure, density, and composition of the fluid. Additionally, the type of fluid and the presence of impurities can also affect thermal conductivity.
4. How is thermal conductivity measured in supercritical fluids?
Thermal conductivity in supercritical fluids can be measured using various techniques, such as the transient hot-wire method or the steady-state heat flow method. These methods involve measuring the temperature difference across a known distance and using mathematical equations to calculate the thermal conductivity.
5. What are the applications of studying thermal conductivity in supercritical fluids?
Understanding thermal conductivity in supercritical fluids has various practical applications in fields such as chemical engineering, geology, and materials science. It can be used to optimize heat transfer processes, design more efficient heat exchangers, and study the behavior of fluids in extreme conditions.
