Thermal conductivity through a cylinder?
In summary, the problem involves a copper tube with specific dimensions and temperature in a room with a different ambient temperature. The rate of heat transfer is calculated using the formula for heat conduction in the radial direction for a cylinder. The resulting answer may seem unrealistic and a different formula for heat conduction should be used for accurate results.
nelson_gslc
A copper tube, of internal radius 6.959mm, overall radius 7.975mm, thickness 1.016mm, contains water at 68 deg Celsius, and is present in a room with an ambient temp of 26.65 deg Celsius. If the tube is 1000mm long, what will be the rate of heat transferred from the copper tube?
k copper = 401 W/mK, A of tube = 0.050m, change in T=42.35 deg C, thickness =0.001016m.
Q/t=kAΔT/d... or Heat transfer across length of cylindrical tubing equation (not specifically known)
I have entered into the Q/t=kAΔT/d equation and received an answer of about 850 000 W, or 850kW, which seems entirely unrealistic. what am I doing wrong?
There are a few things to consider when calculating the rate of heat transfer through a cylinder. First, you have correctly identified the equation to use, Q/t = kAΔT/d, where Q is the rate of heat transfer, t is time, k is the thermal conductivity, A is the surface area, ΔT is the temperature difference, and d is the thickness of the material.
However, in order to get a more realistic answer, it is important to convert all units to the same system. In this case, it appears that you have mixed units of millimeters and meters. The radius of the tube is given in millimeters, while the thickness is given in meters. It is important to convert all units to either millimeters or meters before plugging them into the equation.
Additionally, the given values for the tube's dimensions and temperature difference seem quite small for a copper tube containing water at 68 degrees Celsius. It is possible that there is a mistake in the given values, which is resulting in an unrealistic answer.
In order to get a more accurate answer, it may be helpful to double check the given values and make sure they are all in the same unit system. You may also want to consider using a heat transfer calculator or consulting a heat transfer expert for more precise calculations.
FAQ: Thermal conductivity through a cylinder?
What is thermal conductivity?
Thermal conductivity is a measure of how well a material can transfer heat. It is a physical property that describes the ability of a material to conduct heat through it.
How is thermal conductivity measured?
Thermal conductivity is typically measured in watts per meter-kelvin (W/mK) or British thermal units per hour-foot-degree Fahrenheit (BTU/hr-ft-°F). It is measured by applying a temperature gradient across a material and measuring the rate of heat transfer.
How does thermal conductivity differ in different materials?
Thermal conductivity can vary greatly between different materials. Generally, materials with high thermal conductivity, such as metals, are good conductors of heat, while materials with low thermal conductivity, such as air or insulating materials, are good insulators.
How does thermal conductivity through a cylinder differ from other shapes?
In general, thermal conductivity through a cylinder is similar to thermal conductivity through other shapes. However, the shape of a material can affect its thermal conductivity, as well as other factors such as its composition, density, and temperature.
How is thermal conductivity through a cylinder calculated?
The thermal conductivity of a cylinder can be calculated by using the formula k = (2πkL)/ln(r2/r1), where k is the thermal conductivity, L is the length of the cylinder, r1 is the inner radius, and r2 is the outer radius. This formula takes into account the cross-sectional area of the cylinder and its length.
9K
