Thermal Equilibrium and Longitudinal Relaxation
In summary, the conversation was about solving problem 6.2 from the textbook "Magnetic Resonance Imaging: Physical Principles and Sequence Design." The solution involved using the fact that kT >> hw_0 and letting \alpha = hw_0/kT. After some simplifications, the final form of the solution was found to be M_o \approx \rho_o \gamma^2 \hbar^2 B_o s(2s+1)(s+1)/(3kT).
Shinnobii
Problem 6.2 from Magnetic Resonance Imaging: Physical Principles and Sequence Design.
Show that [itex]M_o \approx \rho_o \frac{s(s+1)\gamma^2\hbar^2}{3kT}B_o[/itex]
[itex] M_o = \rho_o \gamma \hbar \frac{\sum m_s e^{m_s(\hbar w_o / kT)}}{\sum e^{m_s(\hbar w_o / kT)}} [/itex],
where [itex] m_s [/itex] is the magnetic quantum number.
Use the fact that [itex] kT >> \hbar w_o[/itex],
let [itex] \alpha = \frac{\hbar w_o}{kT} [/itex].
Then [itex] e^{\alpha m_s} \approx 1 + \alpha m_s [/itex].
[itex] M_o = \rho_o \gamma \hbar \frac{\sum m_s(1 + \alpha m_s)}{\sum (1 + \alpha m_s)} [/itex],
but [itex] \sum m_s = 0 [/itex], therefore
[itex] M_o = \rho_o \gamma \hbar \frac{\alpha \sum (m_s^2)}{1 + 0} [/itex].
Assuming the above is correct. Am I correct that [itex] \sum m_s^2 = s(2s+1)(s+1) [/itex]?
If so, I get,
[itex] M_o = \frac{\rho_o \gamma^2 \hbar^2 B_o}{kT} s(2s+1)(s+1) [/itex],
since [itex] w_o = \gamma B_o [/itex].
Clearly this is not the correct form, where have I gone wrong?
Welcome to PF!
You did not evaluate the sum in the denominator correctly. ##\sum 1 \neq 1##
Almost. You're off by a simple numerical factor. See http://mathschallenge.net/library/number/sum_of_squares
Likes Shinnobii
Thanks, rookie mistakes. . .
[itex] \sum 1 = (2s + 1) [/itex], since summing from -s to s.
and I forgot a factor a 3
[itex] \sum m_s^2 = \frac{s(2s+1)(s+1)}{3} [/itex] .
Thanks for pointing those out to me!
Related to Thermal Equilibrium and Longitudinal Relaxation
What is thermal equilibrium?
Thermal equilibrium is a state in which two or more objects or systems have reached the same temperature and there is no net flow of heat between them.
What is longitudinal relaxation?
Longitudinal relaxation is a process in which the magnetization of a nuclear spin system returns to its equilibrium state after being perturbed by an external magnetic field.
What factors affect thermal equilibrium?
The factors that affect thermal equilibrium include the temperature, heat capacity, and thermal conductivity of the objects or systems involved, as well as the surrounding environment.
How is thermal equilibrium related to energy?
In thermal equilibrium, the energy distribution between the objects or systems is equal, meaning that the total energy remains constant and there is no net transfer of energy between them.
Why is understanding thermal equilibrium and longitudinal relaxation important?
Understanding these concepts is important in various fields such as physics, chemistry, and engineering, as they play a crucial role in processes such as heat transfer, energy storage, and magnetic resonance imaging.
