Thermal Equilibrium of a system
In summary, at equilibrium, the mixture has a temperature of Tf. The energy gained by water is greater than the energy lost by the two metals, so water will lose energy and the mixture will reach a lower temperature. The book has it set up as if Q(Cu)+Q(Al)+Q(H2O)=0, but this is incorrect. If Q(Cu) is negative, then Q(Cu)+Q(Al)+Q(H2O) is still zero. If Q(Al) is negative, then Q(Cu)+Q(Al)+Q(H2O) is still zero. And finally, if Q(H2O) is negative, then Q(Cu)+Q(Al)+
Feodalherren
605
A combination of .25kg of H2O at 20C, .4kg of Al at 26C and .1kg of Cu at 100C is mixed in an insulated container and allowed to come to thermal equilibrium. Ignore any energy transfer to or from the container and determine the final T of the mixture.
At first this seemed really simple to me I just figured out if the T would be below or above 26 to determine which parts will lose energy and which will gain.
So it turns out that Tf will be less than 26 because the energy required to heat up water to 26 is greater than the copper can supply.
Setting up the equation is where I get lost.
If the energy lost by the Al and Cu must equal the energy gained by the water then shouldn't the equation be:
Q(Cu)+Q(Al)=Q(H2O)
where Q= mCΔT
which is really confusing me.
Ok so if I let the lost energy be negative I get the same thing as the book does but then it seems to me like I'd get the same answer in every case.
The book's way:
-Q(Cu)-Q(Al)=Q(H2O)
But then let's say Tf > 26 then we get
-Q(Cu)=Q(Al)+Q(H2O)
Which simplifies to
exactly the same thing! That doesn't make any sense to me.
One material's loss is another material's gain. And a negative gain is a loss. You have a tendency to want to use positive numbers only, but the book allows negative Q too. Which is good if you consider that a ΔT can be < 0 !
Let Q(Cu) be the energy gained by copper.
Let Q(Al) be the energy gained by aluminum.
Let Q(H2O) be the energy gained by water.
If any of these turn out to be negative, it just means that that particular species lost energy. So,
Q(Cu)=0.1CCu(T-100) is the energy gained by Cu, where T is the final temperature, even if T is less than 100.
The same kind of thing for Al and H2O in terms of T.
If you do it this way, then Q(Cu)+Q(Al)+Q(H2O)=0 makes sense, since the sum of the three energy "gains" is zero.
Likes 1 person
Ah that makes sense. Thx.
I would approach this problem by first understanding the concept of thermal equilibrium and how it applies to this specific system. Thermal equilibrium is a state in which there is no further transfer of heat between two objects or systems in contact with each other. In this case, the insulated container ensures that there is no transfer of heat to or from the surroundings, allowing the system to reach thermal equilibrium.
To determine the final temperature of the mixture, we can use the principle of energy conservation. The total energy of the system before and after mixing must be the same. This means that the energy lost by the Al and Cu must equal the energy gained by the water.
Using the equation Q = mCΔT, where Q is the heat energy, m is the mass, C is the specific heat capacity, and ΔT is the change in temperature, we can set up the following equation:
-Q(Cu) - Q(Al) = Q(H2O)
Where Q(Cu) is the energy lost by the copper, Q(Al) is the energy lost by the aluminum, and Q(H2O) is the energy gained by the water.
Solving for Q(H2O), we get:
Q(H2O) = -Q(Cu) - Q(Al)
Plugging in the values given in the problem, we get:
Q(H2O) = -0.1kg(387J/kg°C)(100°C - Tf) - 0.4kg(897J/kg°C)(26°C - Tf)
Where Tf is the final temperature of the mixture.
Solving for Tf, we get:
Tf = 42.4°C
Therefore, the final temperature of the mixture is 42.4°C. This is lower than the initial temperature of the aluminum and copper, indicating that the water gained more energy from the aluminum and copper than they lost. This makes sense as the specific heat capacity of water is higher than that of aluminum and copper, meaning it requires more energy to raise its temperature.
FAQ: Thermal Equilibrium of a system
What is thermal equilibrium?
Thermal equilibrium is a state in which there is no net flow of heat between two bodies or systems that are in contact. This means that the temperature of both bodies remains constant over time.
How is thermal equilibrium achieved?
Thermal equilibrium is achieved when the rate of heat transfer between two bodies is equal. This can happen through conduction, convection, or radiation. When the temperatures of both bodies are equal, there is no longer a temperature difference to drive heat transfer.
What factors affect thermal equilibrium?
The factors that affect thermal equilibrium include the temperature difference between the two bodies, the heat capacity of the materials involved, and the thermal conductivity of the materials. These factors determine the rate at which heat is transferred and how quickly thermal equilibrium is achieved.
Why is thermal equilibrium important?
Thermal equilibrium is important because it allows for a stable and constant temperature in a system. This is crucial for many processes in science and technology, such as maintaining the temperature of a chemical reaction or keeping electronic devices from overheating.
What happens when a system is not in thermal equilibrium?
When a system is not in thermal equilibrium, there is a temperature difference between the two bodies or systems. This can result in heat transfer, causing the temperature to change until thermal equilibrium is achieved. In some cases, this lack of thermal equilibrium can lead to unstable or unpredictable conditions in a system.
