Thermal exchange between warm object and ideal gas
The discussion focuses on the thermal exchange between a warm object and an ideal gas, emphasizing the conservation of internal energy. It establishes that the total variation of internal energy is zero, leading to the conclusion that the heat lost by the object equals the heat gained by the gas. The equations derived show the relationship between the equilibrium temperature, the specific heat capacities, and the initial temperatures of both the gas and the object. The participants confirm that considering the entire system, including external work, is essential for accurate calculations. The final formula for equilibrium temperature reflects the contributions from both the gas and the object, validating the approach taken.
JayBi
A warm object of mass m and thermal and specific heat c, with temperature T2, is inserted in an adiabatic chamber filled with 1 mol of an ideal (monoatomic) gas at a temperature T1 and atmospheric pressure.
Let T2 > T1.
The chamber has a massless piston, moving without friction.
Considering neglectable the volume of the object, find the equilibrium temperature.
1st principle of thermodynamics
Equation of state of an ideal gas
The total variation of internal energy states
##\Delta U_{tot} = 0##
##\Delta U_{tot} = \Delta U_{ext} + \Delta U_{gas} + \Delta U_{obj}##
with:
##\Delta U_{ext} = Q_{ext} - W_{ext} = -W_{ext}##
##\Delta U_{gas} = Q_{gas} - W_{gas} = Q_{gas} - ( - W_{ext} ) = Q_{gas} + W_{ext}##
##\Delta U_{obj} = Q_{obj} - W_{obj} = Q_{obj}##
hence
##0 = ( - W_{ext} ) + ( Q_{gas} + W_{ext} ) + ( Q_{obj})##
##0 = Q_{gas} + Q_{obj}##
Being
##\Delta U_gas = n c_v (T_eq - 1) = Q_gas + W_ext = Q_gas - p_atm (V_eq - V_1) = Q_gas - n R (T_eq - T1)##
We get
##Q_{gas} = n (cv + R) (T_{eq} - T_1) = n cp (T_{eq} - T_1)##
And being
##Q_{obj} = c m (T_eq - T_2)##
We finally get
##T_{eq} = \frac{n cp T_1 + c m T_2}{n cp + c m}##
My question is: the conservation of the internal energy applies as I showed or should I use it for the object and the gas only:
##\Delta U_{gas} + \Delta U_{ext} = 0##
##n cv (T_{eq} - T_1) + c m (T_eq - T_2) = 0##
Arriving at:
##T_{eq} = \frac{n cv T_1 + c m T_2}{n cv + c m}##
With similar steps?
Thanks
Just follow where the energy goes: the heat released by the object can go to either heating the gas or allowing the gas to do work on the surroundings. Mathematically, we have
\begin{align*}-Q_{\rm obj}&=Q_{\rm gas}\\
-mc(T_{\rm eq}-T_2) &= \underbrace{nC_V(T_{\rm eq}-T_1)}_{\Delta U_{\rm gas}} + \underbrace{p (V_{\rm eq} - V_1)}_{W_{\rm gas}} \\
&= nC_V(T_{\rm eq}-T_1) + n R (T_{\rm eq} - T_1)\\
&= nC_p(T_{\rm eq}-T_1),
\end{align*} which is exactly what you came up with in your first approach.
Thank you Vela!
My doubt started following the first principle, that links internal energy, not heat directly.
Considering the whole system (gas + body + external) seemed the right approach.
Thank you
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
