Thermal Expansion - Both rule and rod
In summary, the length of a brass rod was measured at two different temperatures using a steel ruler. The measured length at 20.0 degrees C was 0.5260 m and at 61.6 degrees C was unknown. Taking into account the expansion of both the rod and ruler, the new measured length of the rod at 61.6 degrees C is calculated by dividing the new length of the rod by the new length of the ruler. Alternatively, it can be calculated by multiplying the original length of the rod by 1 minus the change in length of the ruler. The answer should be expressed to five significant figures.
nrb93
A brass rod's length is measured at 20.0 degrees C with a metre steel rule. The length of the rod is determined to be 0.5260 m. The measurement is repeated at 61.6 degrees C. Taking into account the expansion of the rule and rod, what is the new measured length in metres? Coefficients of linear expansion: Brass: 19.0 X 10-6 K-1; Steel: 11.0 X 10-6 K-1. Express answer to five (5) significant figures.
ΔL = coefficient of linear expansion * ΔT * L
(rearranged original equation)
change in length for rod (brass)
ΔL = (19*10^-6) * 41.6 * 0.5260
= 0.00041575
∴ new length (assuming rule is 1m still) is ΔL + L(original)
= 0.52641575
change in length for rule (steel)
ΔL = (11*10^-6) * 41.6 * 1
= 0.0004576
∴new length = 1.0004576
so new length of rod (after both expanded) in my mind should be;
= 1.0004576 * 0.52641575
= 0.526656637
= 0.52666 (5 sig figs)
I do not have the answer to this question - it is marked online (either correct or incorrect, not giving the answer if incorrect). This answer is apparently incorrect so i must be doing something wrong.
Any help would be appreciated.
welcome to pf!
hinrb93! welcome to pf! :smile:
= 0.52641575
… = 0.52666 (5 sig figs)
if the ruler is expanding, shouldn't the length measured by it be shorter? :wink:
tiny-tim said:
hinrb93! welcome to pf! :smile:if the ruler is expanding, shouldn't the length measured by it be shorter? :wink:
ah, thanks a lot ;) hehe, for further reference for anyone else; you can simply do the new length of the rod divided by the new length of the ruler (as calculated above) OR instead; can do (1 - (ΔL of the ruler)) * rod.
Related to Thermal Expansion - Both rule and rod
1. What is thermal expansion?
Thermal expansion is the tendency of matter to increase in size, volume, or length in response to an increase in temperature.
2. What is the thermal expansion rule?
The thermal expansion rule states that most materials expand when heated and contract when cooled. The amount of expansion or contraction is proportional to the change in temperature and the original size of the material.
3. How does thermal expansion affect objects?
Thermal expansion can cause objects to change shape or size, which can lead to cracks, warping, or even structural failure. It is an important consideration in the design and construction of buildings, bridges, and other structures.
4. What is the coefficient of thermal expansion?
The coefficient of thermal expansion (CTE) is a measure of how much a material will expand or contract with a change in temperature. It is expressed in units of length per degree Celsius (or Fahrenheit) and varies for different materials.
5. How does thermal expansion affect measurement instruments?
Thermal expansion can affect the accuracy of measurement instruments, especially those with metal components. Temperature fluctuations can cause the instrument to expand or contract, resulting in measurement errors. Special calibration techniques are used to compensate for thermal expansion in precision instruments.
