Thermal Expansion Ethanol Problem
In summary: Even if you did know the volume of the cylinder, you still wouldn't be able to determine the volume capacity it is able to hold (the ratio of volume capacity to volume of the cylinder varies). Is this even possible?No, it's not possible to determine the volume capacity without knowing the volume of the cylinder.
Fizzicist
54
You pour 108 cm^3 of ethanol, at a temperature of -10.0 degrees C, into a graduated cylinder initially at 20.0 degrees C, filling it to the very top. The cylinder is made of glass with a specific heat of 840 J/(kg *K) and a coefficient of volume expansion of 1.2 *10^-5 K^-1; its mass is 0.110 kg. The mass of the ethanol is 0.0873 kg.
A. What will be the final temperature of the ethanol, once thermal equilibrium is reached?
(Answer: -.892 degrees C)
B. How much ethanol will overflow the cylinder before thermal equilibrium is reached?
Equation for volumetric expansion:
[tex]\Delta[/tex]V = [tex]\beta[/tex] V0 ([tex]\Delta[/tex]T)
I honestly think this question (part B) is flawed. How could you solve this without knowing V0, the initial volume of the cylinder? And even if you did know the volume of the cylinder, you still wouldn't be able to determine the volume capacity it is able to hold (the ratio of volume capacity to volume of the cylinder varies). Is this even possible?
You can do part 'a' easily.
B, You can't know how much it will overflow without knowing the volume of the cylinder.
But I think you are meant to assume that 108cc of cold ethanol will fill the cylinder to the top and it overflows when it warms - so just work out how much the ethanol expands
Yeah. That seems reasonable...
I didn't like the way this question was asked. It made it sound as if you were supposed account for the contraction of the cylinder because it gave you the coefficient of volumetric expansion for the glass.
Yes - especially because you would need to know the shape of the cylinder!
The volume expansion of the glass isn't the volume expansion of the cylinder.
If you had a thin-walled spherical container and the glass expanded would the volume inside get bigger or would the wall just get thicker and expand outward?
How did you find part A?
You are supposed to account for the contraction of the cylinder.
TY, but I figured this out about a year ago.
Related to Thermal Expansion Ethanol Problem
1. What is thermal expansion?
Thermal expansion is the tendency of matter to change in shape, volume, and density in response to a change in temperature. When heated, most substances expand and when cooled, they contract. This is due to the increased kinetic energy of the particles in the substance, causing them to vibrate and take up more space.
2. What is the thermal expansion ethanol problem?
The thermal expansion ethanol problem refers to the issue of ethanol fuel expanding and potentially damaging fuel systems and engines in vehicles and other equipment. Ethanol, which is commonly added to gasoline as an alternative fuel, has a higher coefficient of thermal expansion than regular gasoline, meaning it expands more with changes in temperature. This can cause issues such as fuel tank distortion, leakage, and engine damage.
3. How does the thermal expansion ethanol problem affect vehicles?
The thermal expansion ethanol problem can affect vehicles in several ways. It can cause fuel tanks to expand and potentially crack, leading to fuel leakage. It can also cause fuel lines and other components to become distorted, which can affect the performance and reliability of the vehicle. Additionally, the increased amount of ethanol in the fuel can lead to corrosion and damage to engine parts.
4. How can the thermal expansion ethanol problem be addressed?
There are several ways to address the thermal expansion ethanol problem. One solution is to use materials that are resistant to ethanol, such as stainless steel or certain types of plastics, in the construction of fuel tanks and other components. Another solution is to limit the amount of ethanol that is added to gasoline, as higher concentrations can exacerbate the problem. Proper maintenance and regular inspections of fuel systems can also help to prevent and address any issues caused by thermal expansion.
5. Is the thermal expansion ethanol problem a serious concern?
Yes, the thermal expansion ethanol problem is a serious concern, especially for vehicles and equipment that are not designed to handle ethanol blends. The expansion of ethanol can cause significant damage and safety hazards if not properly addressed. It is important for vehicle owners and manufacturers to be aware of this issue and take necessary precautions to prevent any potential problems.
20K
