Is Thermal Expansion Fatigue a Concern for Aluminum Alloy Motorcycle Frames?
In summary, thermal expansion fatigue can be a concern for aluminum alloy motorcycle frames. Due to the high operating temperatures and constant heating and cooling cycles, the frame may experience stress and eventually fail. Proper design and material selection can help mitigate this issue, but regular maintenance and monitoring of the frame's condition is also important to prevent potential accidents on the road.
Sefi
Hello, assuming to keep an aluminum alloy motorcycle frame not in use, still, will the daily temperature variations cause thermal fatigue due to the continuous expansions and retractions or is the force developed by a few degrees of variations not sufficient to create microstructural dislocations?
Likes 256bits
Welcome to PF.
Are you asking if a motorcycle with an aluminum frame will degrade over time? I don't think I've heard of that before. Can you give us some links to what is causing you to ask this? Thanks.
Likes 256bits
Hi Berkeman, thanks for the answer, mine was a consideration, from what I read aluminum and aluminum alloys do not have a fatigue limit below which they do not register damage, at each work cycle something in the microstructure is changed. An annual thermal expansion can go from about 0° to 30°, inside even less but there is at least 20° of range. Furthermore, aluminum has a high expansion coefficient, therefore thinking for example of a frame made up of 2 bolted pieces, I imagine that in the points of greatest stress (bolts) these variations can be understood as a work cycle, or perhaps even throughout the frame same. I've always thought that by keeping a car or motorbike only for museum-type display, at least the metal parts wouldn't have been damaged simply by the time.
So what stress is induced on the material if ones takes an annual change in temperature of 30 degrees?
Here is a graph for various materials.
https://material-properties.org/what-is-fatigue-life-s-n-curve-woehler-curve-definition/
For an induced annual thermal stress of 300MPa or so, your aluminium parts should last 10000 years.
Daily, the parts would still last 30 years or so with that same 300 Mpa induced loading.
You just have to determine how much the stress would actually be from the the change in temperature.
And then one can lie in bed at night worrying if it is something to worry about.
Not to say that some micro fractures would not occur, but the parts would have a difficult time failing.
Corrosion from sunlight and weathering can wreck havoc on the machine.
Understood, it would be interesting to know how much stress is induced daily just due to the sudden change in temperature
I may be wrong, but I believe that not much stress, if any, is induced by a change of temperature of the whole aluminum alloy motorcycle frame.
The case of a commercial airplane fuselage is different, because the pressurization cycles induce cyclic internal stress for what it is essentially a cylindrical vessel.
As a matter of fact, heating up whole metal parts and assemblies in big ovens, is a common industrial way to reduce internal stress that have been previously created by heat treatment, welding, or other means of manufacturing.
Perhaps your stamped and welded frame went through a thermal stress relieving process in the factory prior to the final assembly of the motorcycle.
Please, see:
https://gearsolutions.com/departments/hot-seat/stress-relief-is-a-key-step-in-parts-manufacturing/#:~:text=Performing a stress-relieving operation,up to 2-3 hours.
Likes 256bits
I was going to sat something like that about heating a block of aluminium, but you did convey it better then I would have in regards to a practical scenario.
Likes Lnewqban
Please, see:
Thanks for the answer, yes the frames are indeed heat treated to give strength and release the stress in the welds, but having bolted areas or simply expanding and contracting every day due to the change in ambient temperature does not theoretically produce internal dislocations? For steel we could speak of endurance limit, at least theoretically, but with aluminum as far as I understand every little stress or load modifies the internal microstructure or at least that's what I've read in the various researches conducted. Having said that, I don't understand one thing, how is it possible that there isn't a minimum load limit beyond which there will be no fatigue? I imagine that even in aluminum you must have a certain level of energy to allow the dislocations to overcome obstacles and move each other, taking the concept to extremes, if we were to place a weight of 1 gram on aluminum, we would have to see some effort with patience to wait for years? seems like a bold statement, as an ignorant I guess there must be a certain amount of load per cubic Cm or something like that. Still, thermal expansion is a great force too
FAQ: Is Thermal Expansion Fatigue a Concern for Aluminum Alloy Motorcycle Frames?
What is thermal expansion fatigue?
Thermal expansion fatigue refers to the wear and tear that materials experience due to repeated cycles of heating and cooling, which cause expansion and contraction. Over time, this can lead to the development of microcracks and eventual structural failure.
Is aluminum alloy more susceptible to thermal expansion fatigue compared to other materials?
Aluminum alloys generally have a higher coefficient of thermal expansion compared to materials like steel, which means they expand and contract more with temperature changes. However, aluminum alloys are also known for their good thermal conductivity, which helps dissipate heat more effectively. The susceptibility to thermal expansion fatigue depends on the specific alloy and its application.
How does thermal expansion fatigue affect the structural integrity of motorcycle frames?
Thermal expansion fatigue can lead to the formation of microcracks in the motorcycle frame, which may propagate over time and under repeated stress. This can compromise the structural integrity of the frame, potentially leading to failure during operation. Regular inspection and maintenance are essential to identify and address such issues early.
What measures can be taken to mitigate thermal expansion fatigue in aluminum alloy motorcycle frames?
To mitigate thermal expansion fatigue, manufacturers can use specific aluminum alloys that are designed to withstand thermal cycling better. Additionally, proper design considerations, such as stress relief features and the use of thermal barriers, can help reduce the impact. Regular maintenance and inspection are also crucial to detect early signs of fatigue.
Are there any real-world examples of thermal expansion fatigue issues in aluminum alloy motorcycle frames?
While specific examples of thermal expansion fatigue in aluminum alloy motorcycle frames are not commonly publicized, the phenomenon is well-documented in various engineering applications. Manufacturers continuously improve materials and design to address such issues. Riders should follow maintenance schedules and inspect their motorcycles regularly to ensure safety.
20K
