Thermal Expansion in Liquids and Steel
In summary, the conversation discusses a problem with finding the correct final temperature using linear and volume expansion equations. The mistake was made in equalizing the volume changes between the oil and pot, and it is suggested to add a difference of 0.1 to the equation to get the correct answer.
kgm01
The coefficient of linear expansion of steel is 11 x 10-6 K-1 and the and the coefficient of volume expansion of a certain cooking oil is 0.92 x 10-3 K-1. A steel cooking pot is 90% filled with this cooking oil, both at 24 oC. If the pot and oil are both slowly and uniformly heated, the temperature at which the oil will start to spill out of the pot is closest to:
A 50 oC
B 75 oC
C 100 oC
D 150 oC
E 200 oC
∆L=αLi∆T
∆V=βVi∆T
β=3α
This is a repost as I didn't read the community guidelines the first time. Hopefully this is better!
First thing I did was write down both the linear and volume expansion formulas.
I then multiplied my alpha by 3 and used the volume expansion equation for both materials.
∆V oil > ∆V pot, at the point where the oil bubbles over.
I used volumes of 0.9 for the oil and 1 for the pot and made the equations equal to each other as the ∆V would be the same at the point where it bubbled over.
In doing this, I got a final temperature of 24ºC which is clearly incorrect as the final temperature must be higher than the initial.
I have a feeling that my mistake was made in equalising the ∆V but I'm not too sure. Have been attempting this problem in different ways but can't seem to get the right answer.
The correct answer is D
Thanks!
Right. If both the oil and the pot increase their volume by the same amount, then the oil will still have less volume than the pot.
Likes kgm01
Ohh true. So if I did ∆V oil > ∆V pot + 0.1 (difference) I would get the correct answer. Thank you!
Yes. Good.
Related to Thermal Expansion in Liquids and Steel
1. What is thermal expansion?
Thermal expansion is the tendency of materials to expand when heated and contract when cooled. This phenomenon occurs due to the increase in the kinetic energy of the particles within the material, causing them to vibrate and take up more space.
2. How does thermal expansion affect liquids and steel?
Thermal expansion affects liquids and steel in a similar manner. When these materials are heated, their particles gain energy and move further apart, causing them to expand. Conversely, when they are cooled, the particles lose energy and move closer together, resulting in contraction.
3. What causes thermal expansion in liquids and steel?
The main cause of thermal expansion in liquids and steel is the increase in temperature. As the materials absorb heat, their particles gain energy and vibrate more, taking up more space and causing expansion.
4. How is thermal expansion in liquids and steel measured?
Thermal expansion in liquids and steel is typically measured using the coefficient of thermal expansion (CTE). This is a numerical value that represents the amount of expansion or contraction that occurs per unit of temperature change.
5. What are the practical applications of understanding thermal expansion in liquids and steel?
Understanding thermal expansion in liquids and steel is important in a variety of industries, including construction, engineering, and manufacturing. It allows for accurate measurements and predictions, which is crucial in designing structures and systems that can withstand temperature changes without significant damage or failure.
  • Mechanical Engineering
