The Bill
- 374
- 146
- TL;DR Summary
- Materials suitable for a cylinder and piston that is thermally insulating, reasonably durable for low speeds + very slow cycle rate, not a polymer.
What materials would be suitable for a cylinder and piston that is thermally insulating, reasonably durable for low speeds and very slow cycle rates, and not be a carbon or silicon based polymer?
I've been looking at manual lever operated espresso machines lately. Particularly ones that are standalone with no electrical components. You pour hot water into the brew chamber/cylinder and use a lever and piston or a piston air pump to press it through the coffee grounds. The pistons and cylinders are usually thick aluminum or steel, which require a lot of what coffee people call "thermal management" i.e. preheating once or twice with boiling water just before use. There are some which use a polymer piston and cylinder and thus can go without preheating, but some people prefer not to have anything like that touch any hot food or beverage they consume.
There is one which uses a thin wall metal cylinder with an air gap around it which does benefit a little from preheating but can work okay without it. Probably not as good as the polymer ones, but it also doesn't suck enough heat away from the water to ruin light roast brews the way the other metal cylinders do if not preheated. Unfortunately, that particular device (the Cafelat Robot) isn't the most comfortable to use and doesn't have the best workflow.
A typical example of a heavy walled metal cylinder is any of the Flair espresso makers. A polymer example is the Wacaco Nanopresso handheld espresso maker.
So, I was wondering if there are any ceramics, etc. which would be suitable for an application like this. Typical pressures for espresso are 6 to 9 bar in the brew chamber, so being able to safely handle say, 15 or 20 bars just after the thermal shock of adding boiling water to a room temperature cylinder should give a decent safety margin. I'm betting that there isn't anything that would be cost effective and easy to work with, or there would probably be a device using it already, but I'm prepared to be surprised. Maybe there's a coating for, say, aluminum which would be a "good enough" solution?
