Thermal Printing and Ink fading
In summary, the individual is trying to find a way to fade the ink on a thermally printed receipt so that it is less visible over time. They are looking for a fail-safe way to do this, and are not interested in taking advantage of the recipients by invalidating the receipt.
adambenson9771
Hello,
I am not sure if this is the right place but I would appreciate some help.
Basically I have been trying to accelerate the fading of the ink on thermally printer paper.
“Receipts are typically printed on thermal paper, a chemically coated paper that produces text and image when the heat is applied to its surface. Since this kind of paper is susceptible to heat and UV light, extended exposure to these elements will ultimately cause gradual fading. “
I am trying to work out whether there is something I can apply once to cause the ink to fade within 1-7 days, doesn’t have to be fully. I have read somewhere that I could use scotch tape on, as it has polypropylene in it which would cause what I want or getting polypropylene in pure form and applying that.
If you guys have any other ideas, it would be highly appreciated
There are several possible chemical systems.
https://en.wikipedia.org/wiki/Leuco_dye
How you erase it will depend on why you want to reverse or erase the image.
Will you log data then reuse the material in a loop?
The obvious solution is to use a UV lamp to erase the image. Maybe a violet LED would meet the erasure energy requirement, (depending on the chemistry).
Alternatively, for security you could heat it all to make the image black.
“What is direct thermal?
Direct thermal printing uses chemically treated, heat-sensitive label stock that darkens when exposed to heat from the thermal printhead. Leuco dye is the essential ingredient in chemistry that allows this heat reaction to take place. Direct thermal printers have no ink, toner, or ribbon. This simple design makes direct thermal easy to use. However, because a printed direct thermal stock contains the chemistry to darken throughout its life, this darkening reaction can take place unintentionally whenever the material is exposed to high heat. Similar fading can occur with UV exposure. Direct thermal substrates include a select range of paper and film with varying levels of quality, depending on topcoats. ”
https://www.iimak.com/iimak-blog?p=technology-comparison-direct-thermal-vs-thermal-transfer
Welcome to PF.
Well, I guess the direct heat application is too obvious, so you are trying to have some fail-safe way of fading the printing? Can you just ask the recipients to place the receipts on their window sills or something?
  • Haha
Likes sysprog
Thank you for the answers.
I will use a thermally printed receipt as an example. I need something I can apply to it so it kick offs the fading as I would have no access to the receipt once x substance has been applied and left me . Additionally, let's say I have already printed the receipt slightly faded so further fading can be easier.
Leuco dyes are selected based on long life, resistance to fade.
You want the opposite, a poor leuco dye, something that fades quickly.
Do you actually want a vanishing ink ? That can be printed thermally ?
I have looked into vanishing/disappearing ink by blueplanet but their ink is purple. I am looking specifically into something that would fade and be thermally printed.
I hope that you understand that your request sounds a bit criminal. Why do you want to invalidate the written receipts that you give your customers?
I was only using receipts as an example as it is an easy one to be associated with thermal printing
Maybe not criminal, but I expect that if the client was disadvantaged in any way by loss of the information, it would certainly be considered unethical, and is contrary to consumer and record keeping law in some places.
I do not want to be a part of helping you to pull off such a fraud or scam. You must realize now that the closer you hold your cards to your chest, the less help you will get.
Whatever you ever say, you can never not have said. Destroying records doesn't reliably destroy the information on them; there could be a copy somewhere. If someone notices that his receipt is fading fast, he can take a picture of it and print it out. Along with others who have expressed misgivings, most reasons that I can readily imagine for making deliberately ephemeral records are nefarious.
And on that note, it's time to lock this thread. Thread locked.
Likes sysprog, berkeman and jim mcnamara
FAQ: Thermal Printing and Ink fading
What is thermal printing?
Thermal printing is a type of printing technology that uses heat to transfer an image or text onto paper. It is commonly used in receipt printers, label printers, and fax machines.
How does thermal printing work?
In thermal printing, a thermal print head heats up and activates a special thermal paper, which contains a heat-sensitive coating. The heat causes the coating to react and produce an image or text on the paper.
What is ink fading and how does it occur in thermal printing?
Ink fading is when the ink on a printed document starts to lose its color or become lighter over time. In thermal printing, ink fading can occur due to exposure to heat, light, or chemicals, which can cause the thermal paper to darken or turn black.
How can I prevent ink fading in thermal printing?
To prevent ink fading in thermal printing, it is important to store printed documents in a cool, dry place away from direct sunlight or heat sources. Using high-quality thermal paper and avoiding contact with chemicals can also help prevent ink fading.
Can ink fading be reversed in thermal printing?
In most cases, ink fading cannot be reversed in thermal printing. However, there are some specialized thermal printers that use a special type of thermal paper that can be erased and reprinted on multiple times, reducing the risk of ink fading.
22K
