Graduate Thermal stresses in the stress tensor
The discussion centers on incorporating thermal stresses into the mechanical stress tensor for viscous flow. The original equation presented is deemed appropriate for incompressible fluids, but corrections are suggested for compressible fluids, particularly regarding thermal expansion effects. The correct formulation for a compressible viscous fluid includes terms for both pressure and shear stress, with thermal effects typically considered negligible. However, the user seeks to couple temperature changes directly to the Navier equations, indicating a focus on thermal stresses rather than expansion. The conversation highlights the complexities of modeling thermal effects in fluid dynamics, especially in applications like sintering.
hunt_mat
TL;DR
How to I include thermal stresses in the stress tensor
Suppose I have a mechanical stress tensor \sigma. Say I have the stress tensor for viscous flow:
\boldsymbol{\sigma}=-p\mathbf{I}+\frac{1}{2}(\nabla\mathbf{u}+(\nabla\mathbf{u})^{T})
If the thermal flux is given by \boldsymbol{\sigma}_{th}=\alpha T\mathbf{I}, so I have a total flux as:
\boldsymbol{\sigma}=-p\mathbf{I}+\frac{1}{2}(\nabla\mathbf{u}+(\nabla\mathbf{u})^{T})+\alpha T\mathbf{I}
Is this correct?
hunt_mat said:
TL;DR Summary: How to I include thermal stresses in the stress tensor
Is this correct?
Your original equation is for an incompressible fluid.
The correct equation for a compressible viscous fluid without thermal expansion is \boldsymbol{\sigma}=-(p+\frac{2\mu}{3 }\nabla \centerdot \mathbf u)\mathbf{I}+\mu(\nabla\mathbf{u}+(\nabla\mathbf{u})^{T})
With thermal expansion, this becomes \boldsymbol{\sigma}=-(p+\frac{2\mu}{3 }(\nabla \centerdot \mathbf u-\alpha \frac{D T}{Dt}))\mathbf{I}+\mu(\nabla\mathbf{u}+(\nabla\mathbf{u})^{T})The thermal expansion term is usually considered negligible in determining the stress.
With thermal expansion, this becomes \boldsymbol{\sigma}=-(p+\frac{2\mu}{3 }\nabla \centerdot \mathbf u-\alpha \frac{\partial T}{\partial t})\mathbf{I}+\mu(\nabla\mathbf{u}+(\nabla\mathbf{u})^{T})The thermal expansion term is usually considered negligible in determining the stress.
Hi, thanks for your reply. I'm not interested in expansion, but thermal stresses within a material. I want temperature to be coupled to Navier's equations. I would include the \partial_{t}T term as part of the stress tensor to fully couple the derivative?
I'm thinking of sintering with this application, and how thermal expansion affects everything.
Thread 'What is the pressure of trapped air inside this tube?'
As you can see from the picture, i have an uneven U-shaped tube, sealed at the short end. I fill the tube with water and i seal it. So the short side is filled with water and the long side ends up containg water and trapped air. Now the tube is sealed on both sides and i turn it in such a way that the traped air moves at the short side. Are my claims about pressure in senarios A & B correct? What is the pressure for all points in senario C? (My question is basically coming from watching...
  • · Replies 29 ·
  • · Replies 30 ·
  • · Replies 36 ·
