Thermal time scale in tubular flow reactors
In summary, the conversation discusses the process of estimating the time it takes for reagents to reach a set temperature in a tubular reactor for nanoparticle synthesis. The suggested method involves finding the thermal capacity of the fluid, multiplying it by the thermal resistance of the tube, and then using the resulting Time Constant to calculate the estimated time it takes for the reagents to reach 63% of the final temperature. It is noted that this method may not be exact for low flow rates but can serve as a starting point. The conversation also delves into discussing the validity of the lumped system analysis and the Biot number in this situation, with suggestions for alternative modeling approaches.
MSM
So if I have a tubular reactor for nanoparticle synthesis (PTFE tubes ID:2mm). The tubes are heated in a furnace. liquid Reagents at room temperature are pumped by a syringe pump and directed toward the furnace. The reagents decompose to form nanoparticles once they reach the steady-state furnace temperature. How can I estimate how long it takes for the reagents to to reach the set temperature in the furnace once they enter the furnace?
To Estimate:
Find the thermal capacity of the fluid.
Multiply by the thermal resistance of the tube.
This will give you the Time Constant for the heating process. (the time it takes to reach 63% of final temperature)
Multiply by 5.
Cheers,
Tom
p.s. If you are familiar with electrical circuits, the equivalent is a series RC being charged by a voltage source.
p.p.s. You can use this same approach in your previous thread regarding a continuously flowing fluid. It won't be exact (the calculated time will be too short) but is at least a starting point for low flow rates.
Tom.G said:
To Estimate:
Multiply by 5.
Cheers,
Tom
I tried the lumped system analysis, but my understanding is that for this method to be valid, Biot Number (Bi) has to be less than 0.1 (Bi<0.1).
Now consider a fluid with thermal conductivity k=0.14 W/m K, and heat capacity Cp= 2500 J/kg K, and density of 780 kg/m3.
Now for long pipes, Nu=3.68, and with a tube internal diameter of 2 mm, I get a heat transfer coefficient of 257 W/m2 K. This gives us a Bi=0.9. Now with this information , I get a thermal time constant of ~3 s-1. and t~17 seconds to reach final temperature. Does this seem reasonable? because I expected few seconds or lower
In this case, can I still use the method you suggested?
Well you got much deeper into it than I ever did! We could start a long Q&A on this but a better bet is to get the attention of those more versed in the 'non-common' situations.
Let's see if paging @Chestermiller gets better input for you.
If I understand the numbers you supplied, the thermal conductivity of the liquid is extremely low with a moderately high thermal capacity. If that is the case, how about modeling the liquid as a solid thermal barrier with an equivalent 'perfect' (zero size, infinite conductivity) thermal mass at the center?
As I understand the Biot number, it considers convective heat transfer at the surface. With the temperatures you have wouldn't radiative transfer also be significant?
Cheers,
Tom
Cheers,
Tom
See my response to the other thread. https://www.physicsforums.com/threads/heat-transfer-in-thin-tubes.1003289/#post-6495102
Likes Tom.G
FAQ: Thermal time scale in tubular flow reactors
What is the thermal time scale in tubular flow reactors?
The thermal time scale in tubular flow reactors is a measure of the time it takes for the reactor to reach thermal equilibrium. It is influenced by factors such as the reactor design, flow rate, and heat transfer properties of the fluid.
How is the thermal time scale calculated?
The thermal time scale is calculated by dividing the total thermal energy stored in the reactor by the rate at which thermal energy is being added or removed from the system. This can be expressed mathematically as t = E/Q, where t is the thermal time scale, E is the total thermal energy, and Q is the heat transfer rate.
Why is the thermal time scale important in tubular flow reactors?
The thermal time scale is important because it determines the rate at which the reactor can reach thermal equilibrium. If the thermal time scale is too long, it can lead to inefficient heat transfer and longer processing times. On the other hand, if the thermal time scale is too short, it can result in temperature fluctuations and instability in the reactor.
How does the thermal time scale affect reactor performance?
The thermal time scale has a direct impact on reactor performance. A longer thermal time scale means that the reactor will take longer to reach thermal equilibrium, resulting in slower processing times. On the other hand, a shorter thermal time scale can lead to temperature fluctuations and reduced product quality.
Can the thermal time scale be controlled in tubular flow reactors?
Yes, the thermal time scale can be controlled by adjusting various parameters such as the reactor design, flow rate, and heat transfer properties of the fluid. By optimizing these factors, the thermal time scale can be reduced, leading to more efficient and stable reactor performance.
