Thermo - double Vrms, find heat required
In summary, the conversation discussed a problem involving a diatomic gas undergoing a process in which the pressure is directly proportional to the volume until the rms speed of the molecules has doubled. The solution involved calculating the change in internal energy and accounting for any work done by the gas to find the amount of heat required for the process. There may have been a misprint in the answer provided in the textbook.
undagada
n moles of a diatomic gas with CV =5/2 R has initial pressure pi and volume Vi. The gas undergoes a process in which the pressure is directly proportional to the volume until the rms speed of the molecules has doubled.
a. Show this process on a pV diagram.
b. How much heat does this process require? Give your answer in terms of n, pi , and Vi
PV = 2/3 N εavg
εavg = 1/2 mv2
PV = nRT
E = 5/2 nRT
Q = ΔE
Part a was done simply by linearly increasing Pi and Vi to 4 Pi and 4 Vi respectively.
Part b:
[itex]ΔE = \frac{5}{2} nRΔT[/itex]
[itex] = \frac{5}{2} nR(\frac{4P_iV_i}{nR} - \frac{P_iV_i}{nR})[/itex]
[itex] = \frac{15}{2} P_iV_i[/itex]
However, the answer in the back is:
[itex]\frac{15n+3}{2} P_iV_i[/itex]
Not sure where the n and +3 came from, maybe PV = 2/3 N εavg? Plugging that in doesn't seem to work though.
Welcome to PF!
undagada said:
Q = ΔE
Does this equation account for any work done by the gas?
This would cause PV to increase by a factor of 16.
Part b:
OK, now you have PV increasing by a factor of 4. I believe this is correct for ΔE. However, to get Q you will need to take into account any work done by the gas.
I think there must be a misprint in this expression. Q should be proportional to the number of moles.
You're right, it should be 2 Pi and 2 Vi.
Okey dokey.
[itex]\Delta E = \frac{15}{2} P_iV_i[/itex]
[itex] W = \int pV [/itex]
[itex]\Delta E = Q -W_s[/itex]
[itex] \frac{15}{2} P_iV_i = Q - ( \frac{1}{2} (2V_i - V_i)(2P_i - P_i) + (P_i V_i) ) [/itex]
[itex] Q = \frac{15}{2} P_iV_i + \frac{P_i V_i}{2} + P_i V_i [/itex]
[itex] Q = \frac{18}{2} P_iV_i[/itex]
That looks a little better. I would not be surprised if the answer is a misprint; that has happened a lot for this textbook. (Knight Physics 3rd ed.)
Thanks for your help!
Related to Thermo - double Vrms, find heat required
1. What is the formula for calculating Vrms?
The formula for calculating Vrms is Vrms = √(3RT/M), where R is the gas constant, T is the temperature in Kelvin, and M is the molar mass of the gas.
2. How is Thermo - double Vrms related to heat?
Thermo - double Vrms is a thermodynamic expression that relates the average velocity of gas molecules to the amount of heat required to raise the temperature of the gas. It is used to calculate the amount of heat needed to increase the temperature of a gas at constant volume.
3. How do you solve for heat required using Thermo - double Vrms?
To solve for heat required using Thermo - double Vrms, you need to first calculate the average velocity of the gas molecules using the given temperature and molar mass. Then, you can use the formula Q = (3/2)NkΔT, where N is the number of gas molecules, k is the Boltzmann constant, and ΔT is the change in temperature, to calculate the amount of heat needed.
4. Can Thermo - double Vrms be used for all types of gases?
Yes, Thermo - double Vrms can be used for all types of gases as long as the temperature and molar mass are known. However, it is important to note that this expression assumes an ideal gas behavior, so it may not be accurate for real gases at high pressures or low temperatures.
5. What are the units for Thermo - double Vrms?
The units for Thermo - double Vrms are meters per second (m/s) for velocity and joules (J) for heat required.
  • Classical Physics
