Thermo physics (Phase diagram Phase changes)
In summary, the first question is asking which option is correct for a substance in a pure phase heated at constant pressure in terms of the heat absorbed. The options presented are the molar heat capacity, amount of substance, change in kinetic energy of molecules, change in potential energy of molecules, average distance between molecules, molar enthalpy of phase change, and change in temperature. After evaluating the options, the correct answer is (c) and (d) since the heat absorbed and temperature increase, causing an increase in kinetic energy. (g) is also correct since it is not a phase transition. However, there may be additional options that may have been missed. In the second question, the options are related to heat transfer during a
tvtokyo
Hi have some thermal physics question would like to clarify. Thanks :)
Question 1: For a substance in a pure phase heated at constant pressure, the heat absorbed is related to ____________
(a)the molar heat capacity of the substance
(b)the amount of substance
(c)the change in the kinetic energy of the molecules
(d)the change in the potential energy of the molecules
(e)the average distance between molecules
(f)the molar enthalpy of the phase change
(g)the change in temperature
Which option should be right?
I have no idea for this question but in this question there should be no phase change right compared to the bottom question?? :
(a) This should be constant? since there is no phase change?
(b) remain the same ? (no phase change)
(c) should increase since heat absorbed and Temperature increases so K.E increase
(d) Not sure?? should increase also?
(e) should not change? since the substance is at the same state (no phase change)?
(f) Not sure
(g) Should change. Since this is not a phase transition??
So my answer is (c) (d) (g) . Is it correct? and did I miss out anything?
Question 2: During a phase change of a pure substance, the heat transfer is related to _______________
(a)the change in the kinetic energy of the molecules
(c)the molar heat capacity of the substance
(d)the average distance between molecules
(e)the change in the potential energy of the molecules
(f)the change in temperature
(g)the molar enthalpy of the phase change
(a) Wrong since phase transition K.E does not increase.
(f) No change in temperature at phase transition
(g) Not sure?
Is (b) (d) (e) correct for this? Any other additional option I missed up.
Is (c) also correct? Since after a phase change for example solid to liquid phase, the heat capacity of solid and liquid also differs??
Hi tvtokyo. http://img96.imageshack.us/img96/5725/red5e5etimes5e5e45e5e25.gif
In Q1, I'm wondering why you dismissed (a) and (b)?
Have you googled "molar heat capacity"? You can't hope to properly address the question if you don't know what the terms mean.
The greater the mass that is heated through Δt, the greater the kJ needed, surely?
Good luck with your studies.
Related to Thermo physics (Phase diagram Phase changes)
What is a phase diagram?
A phase diagram is a graphical representation of the physical states of a substance as a function of temperature and pressure. It shows the conditions under which a substance exists as a solid, liquid, or gas.
What are the three phases of matter?
The three phases of matter are solid, liquid, and gas. These phases are determined by the strength of intermolecular forces and the amount of energy present in the substance.
How does a substance change phases?
A substance changes phases when it gains or loses enough energy to overcome the intermolecular forces holding its particles together. For example, a solid will melt into a liquid when enough energy is added to break the bonds between its particles.
What is the difference between a phase change and a chemical change?
A phase change is a physical change in a substance, meaning the molecules remain the same but their arrangement and movement changes. A chemical change, on the other hand, involves a chemical reaction where the molecules are rearranged and new substances are formed.
How does a phase diagram help in understanding a substance?
A phase diagram helps in understanding a substance by showing the range of temperatures and pressures at which it exists as a solid, liquid, or gas. It also provides information about the conditions under which phase changes occur, allowing for better prediction and control of these changes.
