{Thermochemistry} Hess' law problem
Your name] In summary, to calculate the heat released by burning one gram of benzene, we first determine the amount of moles in one gram of benzene using its molar mass. Then, we use the balanced chemical equation and the given values for the standard enthalpies of formation to calculate the heat released. The final answer is -0.388 kJ.
hiuting
23
Benzene (C6H6) is a liquid which burns in air to form liquid water and carbon dioxide. Calculate the heat released by burning one gram of benzene.
[tex]\Delta[/tex]Hof, kJ/mol
carbon dioxide (g) = -393.5
water (l) = -285.8
benzene (l) = 49.04
2C6H6 (l) + O2 (g) >> 12 CO2 (g) + 6 H2O (l)
I got -25.42 kJ ... do I have to find the amount of moles in 1 gram of benzene first? and then do the calculations?
Thank you for your question. To calculate the heat released by burning one gram of benzene, we first need to determine the amount of moles in one gram of benzene. This can be done by using the molar mass of benzene, which is 78.11 g/mol. So, one gram of benzene contains 0.0128 moles (1 g / 78.11 g/mol = 0.0128 mol).
Next, we can use the balanced chemical equation you provided to calculate the heat released. According to the equation, 2 moles of benzene react to form 12 moles of carbon dioxide and 6 moles of water. This means that for every 2 moles of benzene, 12 moles of carbon dioxide are produced. Therefore, for 0.0128 moles of benzene, (0.0128 mol / 2 mol) x 12 mol = 0.077 mol of carbon dioxide is produced.
We can now use the given values for the standard enthalpies of formation (\DeltaHof) to calculate the heat released. Using the equation \DeltaH = \sum n \DeltaHof(products) - \sum n \DeltaHof(reactants), we get:
\DeltaH = (0.077 mol)(-393.5 kJ/mol) + (0.0128 mol)(-285.8 kJ/mol) - (0.0128 mol)(49.04 kJ/mol)
= -30.34 kJ/mol
Since we are dealing with 0.0128 moles of benzene, we need to multiply this value by 0.0128 to get the heat released for one gram of benzene.
Therefore, the heat released by burning one gram of benzene is -30.34 kJ/mol x 0.0128 mol = -0.388 kJ.
I hope this helps answer your question. If you have any further inquiries, please don't hesitate to ask.
Related to {Thermochemistry} Hess' law problem
1. What is Hess' Law and how does it relate to thermochemistry?
Hess' Law is a principle in thermochemistry that states that the total enthalpy change of a reaction is independent of the pathway taken to reach the final products. In other words, the overall enthalpy change of a reaction is the same regardless of whether it occurs in one step or multiple steps.
2. How do you solve a Hess' Law problem?
To solve a Hess' Law problem, you need to follow a few steps. First, write out the given chemical equations and their corresponding enthalpy changes. Then, manipulate the equations to get the desired overall reaction and combine the enthalpy changes accordingly. Finally, calculate the final enthalpy change using the combined enthalpy values.
3. What is the significance of Hess' Law in thermochemistry?
Hess' Law is significant because it allows us to calculate the enthalpy change of a reaction even when direct measurements are not possible. This is because it does not matter how the reaction is carried out, the enthalpy change will always be the same. It also helps in predicting and understanding the thermodynamics of a reaction.
4. Can Hess' Law be applied to all chemical reactions?
Yes, Hess' Law can be applied to all chemical reactions as long as the reactions are thermodynamically feasible. This means that the reactions must be able to occur spontaneously without the input of external energy.
5. Are there any limitations to Hess' Law?
One limitation of Hess' Law is that it only applies to reactions in the gas phase, as it assumes that the gases involved behave ideally. It also does not take into account changes in temperature and pressure, which can affect the enthalpy change of a reaction. Additionally, the law assumes that all reactions are reversible, which may not always be the case.
26K
