Thermocouples, Voltage, and Circuits
In summary, a thermocouple is a temperature sensor that works by utilizing the Seebeck effect, which creates a voltage when there is a difference in temperature between the two ends of the sensor. These sensors are highly accurate, with most commercially available ones having a precision of 1-2 degrees Celsius. The voltage produced by a thermocouple is directly proportional to the temperature difference, which allows for precise temperature measurements and control in circuits. Some common applications of thermocouples include temperature measurement in industrial processes, monitoring of engine and exhaust temperatures in vehicles, and temperature control in appliances and scientific experiments.
compsciguy
Hello all, I have a physics project that I am working on in which I have to develop a heat engine to do something useful. Rather than do the classic putt-putt-boat or candle-powered turbine (which have to be built from scratch), I thought I'd do something unique, and build a thermocouple.
However, I have run into a few problems.
First of all, a thermocouples voltage output is rather small (about 30 mV or less), and it's power output is minute (don't know what it is precisely though, just small). In order to run a very small LED light, I need around 2 amps of energy at around 2-3 volts.
Because of this, I run into problems... my thermocouple isn't powerful enough to run the lightbulb.
Even if I run it in array circuits (which adds up the voltage), it still is not very much power nor is it worth paying for.
Thus, I am looking for one of a few possible solutions
-Is there another low voltage device that does 'useful' work that I could power up that requires much less voltage and power that you know of?
-Is there a technique you know that will easily boost/store voltage so that way the lightbulb may be turned on periodically, if at all?
-If I was to use a battery or capacitor of some sort (which capacitors I don't think would work since they have a max voltage output depending on the device being used and aren't set by the capacitor), what would you suggest and how long would it take to charge up on the low energy of the thermocuple?
-Should I just switch to an easier heat engine?
Thanks in advance, and if this would be more appropriate in another section of the forums, please have it moved for me, thanks =).
Thermocouple Metal Pairing with Sensitivity
Chromel/Constantan - 68
Iron/Constanta - ~52
Chromel/Alumel - 41
Copper/Constanta - ~43
These metals are all somewhat cheap, which is why I am using them over other metals.
Chromel is 90% Nickel, 10% Chrome. Alumel is 96% Nickel, 2% Manganese, 2% Aluminum. Constantan is 55% Copper, 45% Nickel.
I can use any possible circuit or storage type you can think of, although I would hope it wouldn't be too expensive.
I don't know of any other equations that would be useful... perhaps some electrical ones... but not sure.
Haven't bought anything yet because of the likeliness of it not being able to work out. I've read a lot of information and looked at many of other people's attempts though.
The metals also have to be bought online (or I have to go out to a store very far away) so yah, it's better for me to plan through it first.
Thanks again for the help!
Best Wishes,
CompSciGuy
Dear CompSciGuy,
I understand your frustration with your thermocouple project and the limitations you have encountered. It can be challenging to work with small voltage outputs and limited power sources, but I believe there are possible solutions to your problem.
One option would be to use a voltage booster or amplifier to increase the voltage output of your thermocouple. This can be achieved through the use of a transformer or a DC-DC converter. This would allow you to power devices that require higher voltages, such as your LED light.
Another option would be to use a thermoelectric generator (TEG) instead of a thermocouple. TEGs are designed specifically to generate electricity from heat differentials and can produce higher voltage outputs than thermocouples. They can also be easily connected in series to increase the voltage output.
If you do choose to stick with the thermocouple, I would suggest using a battery or capacitor to store the energy generated by the thermocouple. This would allow you to accumulate enough energy to power your LED light for a longer period of time. The charging time would depend on the capacity and efficiency of the battery or capacitor, but it should not take too long with a small power source like a thermocouple.
I would also recommend looking into more efficient metal pairings for your thermocouple. While the metals you have chosen may be inexpensive, they may not be the most efficient at converting heat into electricity. There are other metal combinations that have a higher sensitivity and can produce a larger voltage output.
I hope these suggestions help you in finding a solution for your project. It is always good to explore different options and try out different circuits and components to achieve your desired results. Good luck with your project!
Related to Thermocouples, Voltage, and Circuits
1. What is a thermocouple and how does it work?
A thermocouple is a temperature sensor that consists of two different metal wires joined together at one end. When there is a difference in temperature between the two ends, it creates a voltage, known as the Seebeck effect. This voltage can be measured and used to determine the temperature difference.
2. How accurate are thermocouples?
Thermocouples have a high degree of accuracy, with most commercially available thermocouples having an accuracy of around 1-2 degrees Celsius. However, the accuracy can vary depending on the type of metal used in the thermocouple and the temperature range it is being used in.
3. What is the relationship between voltage and temperature in a thermocouple?
The voltage produced by a thermocouple is directly proportional to the temperature difference between the two ends. This means that as the temperature difference increases, so does the voltage, and vice versa. This relationship is known as the Seebeck effect.
4. How do thermocouples work in circuits?
Thermocouples can be used in circuits to measure temperature and control other components. They are typically connected to a voltage measuring device, such as a voltmeter, to read the voltage produced. This voltage can then be used to control other components, such as heaters or cooling systems, to maintain a desired temperature.
5. What are some common applications of thermocouples?
Thermocouples have a wide range of applications, including temperature measurement in industrial processes, monitoring engine and exhaust temperatures in automobiles, and temperature control in appliances such as ovens and refrigerators. They are also commonly used in scientific experiments and research to measure and control temperature in various environments.
