Thermodyamics - Chemical Potential
In summary: E, dN, and dV)In summary, the homework statement states that:-dE=TdS-PdV+\mu dN-PV=NT-Cv=\frac{3}{2}N
decerto
87
Given [itex]dE=TdS-PdV+\mu dN[/itex], [itex]PV=NT[/itex] and [itex]Cv=\frac{3}{2}N[/itex]
Find E
That part that is confusing me is the chemical potential, not sure what to do with it. Finding the energy for the ideal gas is pretty simple without it
[itex]dE=T\frac{\partial S}{\partial T}dT+(T\frac{\partial S}{\partial v}|_T-P)dV+\mu dN[/itex] expanding dS
[itex]dE=C_v dT+(T\frac{\partial P}{\partial T}|_V-P)dV+\mu dN[/itex] by maxwell relation
[itex]dE=C_v dT+(T\frac{N}{V}-P)dV+\mu dN[/itex] by taking derivative of ideal gas law
[itex]dE=C_v dT+(P-P)dV+\mu dN[/itex]
[itex]dE=\frac{3}{2}NdT+\mu dN[/itex]
[itex]E=\int\frac{3}{2}NdT+\int\mu dN[/itex]
Without the chemical potential its simply [itex]E=\frac{3}{2}NT[/itex] using [itex]E(t=0)=0[/itex] and pretty much no source I've looked at makes reference to the chemical potential when calculating the internal energy so I'm confused.
Here are some comments by the person who set homework when someone asked him about N being constant
What happened to the gas constant R in your equations?
Chet
Chet
It should be k for number of particles N, I guess the problem is in units where k=1
Never heard of such a system of units. Help me there ... :)
You make use of the ideal gas law. Is there something missing in the problem statement ? Like: "Find E for an ideal gas" instead of "find E" ?
Please do BvU and me a favor and put the k back in. The equations, as they stand, hurt our eyes to look at them.
If you change the number of molecules of the gas N at constant T and P, how does that affect the volume per molecule v, the internal energy per molecule e, and the entropy per molecule s?
Chet
http://en.wikipedia.org/wiki/Natural_units Pretty much all those unit conventions set k=1
Well the equations of state are for an ideal gas so yes I am finding E for an ideal gas
Chet
So from the ideal gas law with T and P constnat [itex]V \propto N[/itex] so Volume per molecule [itex]V/N \propto 1[/itex] so its a constant. I don't have a formula for the internal energy so i can't answer how changing N affects it, do I not need to know something about [itex]\mu[/itex]?
If you have a container with N molecules of a gas at temperature T and pressure P (and internal energy E) and you have a second container with 2N molecules of exactly the same gas at the same temperature and pressure (i.e., twice the volume), what is the internal energy of the gas in the second container? How do the entropies of the gases in the two containers compare?
Chet
Chet
By extensivity of E it's 2E, similarly it's 2S
Excellent. So we can write:
V = N v(T,P)
E = N e(T,P)
S = N s(T,P)
and thus,
dV = N dv + v dN
dE = N de + e dN
dS = N ds + s dN
Now, see what happens when you substitute these relations into your original equation for dE. (Make sure you collect terms that multiply dN, and also collect terms that multiply N).
Chet
V = N v(T,P)
E = N e(T,P)
S = N s(T,P)
and thus,
dV = N dv + v dN
dE = N de + e dN
dS = N ds + s dN
Chet
I get [itex]N(de-Tds+Pdv)=(-e+Ts-Pv+\mu)dN[/itex]
Still unsure what to do, there is something key I'm missing here...
This equation contains a wealth of important information.
First of all, since N and dN are arbitrary and independent of one another, the two terms in parenthesis in the equation must be equal to zero:
[tex]\mu=e-Ts+Pv=g(T,P)=G/N[/tex]
[tex]de=Tds-Pdv[/tex]
The first relationship tells us that the chemical potential is equal to the Gibbs free energy per molecule g=G/N.
The second equation is our basic first/second law equation, but without the chemical potential term present now. It tells us, from your previous analysis, that
[tex]e = \frac{3}{2}kT[/tex]
So, irrespective of whether the chemical potential term is present in your original equation, we conclude that, for an ideal gas, the internal energy is given by
[tex]E = \frac{3}{2}NkT[/tex]
Chet
Chet
Sorry from my original analysis I end up with [itex]de=T\frac{\partial s}{\partial T}|_vdT[/itex]
with s=S/N
[itex]ds=\frac{\partial s}{\partial S}dS+\frac{\partial s}{\partial N}dN[/itex]
[itex]\frac{\partial s}{\partial T}|_v=\frac{1}{N}\frac{\partial S}{\partial T}|_v-\frac{S}{N^2}\frac{\partial N}{\partial T}|_v[/itex]
How do I show the term on the right is zero?
Yes. This equation is correct. You also have that:
[tex]\frac{\partial s}{\partial T}|_v=\frac{C_v}{T}[/tex]
So,
[itex]de=C_vdT[/itex]
I wasn't able to make sense out of the rest of what you wrote.
The key to this problem is recognizing that, for a single phase, single component, closed system, the chemical potential ##\mu## is not some arbotrary mysterious quantity, but, instead, is directly related to the system parameters E, S, T, P, V, and N by the equation:
[tex]\mu=\frac{E+PV-TS}{N}[/tex]
So,
No I have [tex]\frac{\partial S}{\partial T}|_v=\frac{C_v}{T}[/tex] where S=sN
It should be:
[tex]\frac{\partial S}{\partial T}|_v=N\frac{C_v}{T}[/tex]
where Cv is the heat capacity per molecule (or mole, depending on which units you are using).
Chet
Chestermiller said:
It should be:
Chet
I am really lost, I said at the top [itex]C_v=\frac{3}{2}N [/itex]
If I have [itex]de=C_vdT[/itex] which I still don't understand how you got from [itex]\frac{\partial s}{\partial T}|_v[/itex]
then [itex]e=C_vT[/itex]
[itex]e=\frac{3}{2}NT[/itex]
which gives [itex]E=\frac{3}{2}N^2T[/itex]
The notation is driving both of us crazy. Yiiiiii.
Let's follow the convention that lower case symbols are per molecule, and upper case symbols are for extensive total. Then:
[tex]c_v=\frac{3}{2}k[/tex]
[tex]C_v=\frac{3}{2}Nk[/tex]
[tex]de=c_vdT=\frac{3}{2}kdT[/tex]
[tex]dE=C_vdT=\frac{3}{2}NkdT[/tex]
Chet
Chet
Ok that's fine but what I have is [itex]de=T\frac{\partial s}{\partial T}|_vdT[/itex] and I was given [itex]T\frac{\partial S}{\partial T}|_v=C_v=\frac{3}{2}N[/itex]
So I need to relate [itex]\frac{\partial s}{\partial T}|_v[/itex] and [itex]\frac{\partial S}{\partial T}|_v[/itex]
which I tried to do by expanding ds(S,N) above and I didn't simply get [itex]\frac{\partial s}{\partial T}|_v=\frac{1}{N}\frac{\partial S}{\partial T}|_v[/itex] like you are saying, there is another term with [itex]\frac{\partial S}{\partial N}|_S\frac{\partial N}{\partial T}|_v[/itex] is this term simply zero?(This is in post 13)
Hi Decerto,
I need to apologize. I just haven't been able to figure out how to explain this in a way that works for you. Maybe someone with a background closer to yours could do better. Please don't take this personally and please don't give up. But I'm going to have to withdraw from contributing to this thread.
Chet
Related to Thermodyamics - Chemical Potential
What is chemical potential in thermodynamics?
Chemical potential is a concept in thermodynamics that describes the potential energy of a substance due to its chemical composition and relative position with respect to other substances. It is a measure of the energy required to add or remove a particle from a system at constant temperature, pressure, and composition.
How is chemical potential related to Gibbs free energy?
Chemical potential is directly related to Gibbs free energy through the equation ΔG = ΔH - TΔS, where ΔH is the change in enthalpy, T is the temperature, and ΔS is the change in entropy. Chemical potential is the partial derivative of Gibbs free energy with respect to the number of particles in a system.
What is the difference between chemical potential in gases and liquids?
In gases, chemical potential is primarily determined by the pressure and temperature of the system, while in liquids it is influenced by intermolecular forces and the concentration of the substance. In general, chemical potential in gases is easier to measure and predict due to simpler molecular interactions.
How does chemical potential affect phase changes?
The chemical potential of a substance can determine its tendency to undergo a phase change, such as from liquid to gas or solid to liquid. When the chemical potential of a substance is equal in two phases, the system is at equilibrium and no phase change will occur. However, if the chemical potential is not equal, the substance will tend to move towards the phase with the lower chemical potential.
Why is chemical potential important in chemical reactions?
Chemical potential is important in chemical reactions because it determines the direction of the reaction and the amount of energy that will be released or absorbed. If the chemical potential of the reactants is higher than that of the products, the reaction will proceed spontaneously and release energy. However, if the chemical potential of the products is higher, energy must be supplied to the system for the reaction to occur.
