Thermodynamic/Carnot efficiency
  • Thread starter contred
  • Tags
    Efficiency
In summary, a novel heat engine is being considered for producing work from wastewater discharge from a food processing plant. The wastewater leaves the plant at 35 degrees Celsius and is discharged into the ocean at a rate of 1000 gallons per minute. The maximum power that could be produced by this heat engine can be calculated using the rate of flow and assuming a convenient time, and the thermal cycle efficiency would be 8%. The equations used include calculating delta T, total heat, Carnot efficiency, and power.
contred
A novel heat engine is being considered for producing work from the thermal energy contained in the wastewater discharge from a large food processing plant. On an average day, 35 degree celcius wastewater leaves the plant at and is discharged into the ocean at 1,000 gallons PER minute. if the average annual ocean temperature is 10 degree celcius at that location, what is the maximum power that could be produced by this heat engine? What would be the thermal cycle efficiency of your maximum power engine? You can assume that the heat capacity of water at constant pressure is contant at 4,200 J/Kg K.
delta T = Tf - Ti
Q = mc delta T
Carnot n=1-(Tc/Th)
W= total heat times Carnot n
P=W/t
1000 Gallons per minute = 63.09 Kg per sec
T1 = 10 +273 = 283K
T2 = 35 +273 = 308K
Delta T = 25 K
Carnot η = 1- 283K/308K = 0.08 = 8%
How can I calculate the maximum power with the rate flow and without the time? I think i am missing an equation.
You can choose a convenient time. Since you calculated the rate in kg/s, you have t and m. You can then determine Q (Total Heat), since you have C (Heat Capacity) as a given, and you calculated m/t and you have T. Once you have Q, you can calculate W and then P, using the same t that you chose earlier.
Related to Thermodynamic/Carnot efficiency
What is thermodynamic efficiency and why is it important?
Thermodynamic efficiency is a measure of how well a system converts energy into work. It is important because it can help us understand the performance of various systems and identify ways to improve efficiency.
What is the Carnot cycle and how does it relate to thermodynamic efficiency?
The Carnot cycle is a theoretical thermodynamic cycle that represents the maximum efficiency that any heat engine can achieve. It relates to thermodynamic efficiency because it sets the upper limit for the efficiency of any real-world heat engine.
How is thermodynamic efficiency calculated?
Thermodynamic efficiency is calculated by dividing the output work of a system by the input heat. This can be represented by the equation: efficiency = (output work / input heat) x 100%.
What factors can affect the thermodynamic efficiency of a system?
Several factors can affect thermodynamic efficiency, including the design and construction of the system, the type of fuel or energy source used, and the temperature difference between the hot and cold reservoirs.
How can thermodynamic efficiency be improved?
Thermodynamic efficiency can be improved by minimizing energy losses, using more efficient materials and designs, and optimizing the temperature difference between the hot and cold reservoirs. Additionally, regular maintenance and proper operation of the system can also help improve efficiency.
12K
