Thermodynamic energy and Hamiltonian
In summary, CharlesLink's calculations show that minimization of energy is justified from thermodynamic considerations, which means that energy of charges in the electromagnetic field, which usually needs to be extracted from the Hamiltonian, is the same as the energy of the system in the thermodynamic sense.
vsv86
25
Hello Everyone
This question is motivated by a small calculation I am doing on polarization of bodies in external electric field.
What I wanted to do is this:
1) Mesh the region
2) Prescribe uniform (and non-changing) positive charge distribution
3) Prescribe (initially) uniform negative charge density (net charge is zero)
4) Vary the negative charge density, i.e. shuffle the charges between mesh elements
5) Calculate the potential (##\phi##) due to distributed charge density (##\rho##)
6) Compute energy ##U=\int{d^3 r (\phi+\phi_{ext})\rho}##, where ##\phi_{ext}## is due to applied field
7) If the energy has decreased, keep the new negative charge distribution, otherwise go back to the previous distribution
8) Repeat from step 4 onwards., keep going until it converges
What I realized now is that minimization of energy is justified from thermodynamic considerations, i.e. this is a restatement of the second law. This means however, that I now need to understand what is the relationship between the energy of charges in the electromagnetic field, which I would usually extract from the Hamiltonian, and the energy of the system in the thermodynamic sense. I expect the two must be the same, but I am finding it hard to justify it with non-handwave'y arguments.
Can anyone suggest a some literature (or a simple argument) on the matter?
Kind regards
PS: All of this is for electrostatics
Science news on Phys.org
In the formation of electric dipoles, for a linear material, the dipole is a stretching, like a mass on a spring, to a higher potential energy state. The equation ## P=\chi E ## is similar to ## F=-k x ##. (## P=q d ##, where ## d ## is the distance the dipole is stretched. The result is ## d=\alpha E ## where ## \alpha=\frac{\chi}{q} ##). ## \\ ## A compete thermodynamic electrostatic description would need to have this attractive linear response incorporated into it somehow. Then there is of course energy per unit volume ## U=-\vec{P} \cdot \vec{E} ##. (The vector ## \vec{E} ## is the applied electric field). ## \\ ## Doing the thermodynamics to a mass on a spring in a uniform gravitational field, the equilibrium point is reached when the total potential energy is minimized. ## U=-\vec{P} \cdot \vec{E} ## could be considered to be the negative charge moving in the externally applied electric field, and it would be the analog of the mass in the gravitational field, with ## U_g=mgh ##. (## mg \rightarrow q \vec{E} ##, and ## h \rightarrow d##). The electrostatic attraction of the negative and positive charges would be analogous to the spring constant force. ## U_{spring}=\frac{1}{2}kh^2 ## . ## U_{total}=U_g+U_{spring } ## is minimized when ## \frac{dU_{total}}{dh}=mg+kh=0 ##, so that ## h=-\frac{mg}{k} ##.
Dear Charles Link
Thanks for the reply.
Why would electrostatic description be linear? I know about the dielectric constant and susceptibility approaches to describing response of materials to electromagnetic field, but, as far as I know, this is only an approximation, with no claim to being fundamental. Afterall, where linear response stops, the nonlinear optics begins, and nonlinear optics is very much alive and well.
This is where I have a problem. What is the definition of energy? I am happy with the definition that says energy is the (scalar) quantity of the system that is conserved when system (i.e. the Lagrangian ##L##) has no explicit time-dependence (##\left(\partial{L}/\partial{t}\right)_{\vec{r},\,\dot{\vec{r}},\dots}##) . One can then take the correct Lagrangian for the electromagnetic field + charges (and we know it is the correct one because it generates Maxwell's Equations), and extract the expression for the energy, such as the one you gave. More explicitly:
The charge density for a point-like electric dipole (##\vec{p}##) at the origin is ##\rho=-\vec{\nabla}.\vec{p}\delta^{(3)}\left(\vec{r}\right)##, so
##\int d^3 r\, \rho \phi=-\int d^3 r\,\vec{\nabla}.\vec{p}\delta^{(3)}\left(\vec{r}\right) \phi =\vec{p}. \int d^3 r\,\delta^{(3)}\left(\vec{r}\right) \vec{\nabla}\phi = \vec{p}.\vec{\nabla}\phi\left(\vec{0}\right)=-\vec{p}.\vec{E}##
But how do we know that this is the thermodynamic energy? The one that is used to define the temperature for example ##dU=TdS+dW##, where ##U## is energy, ##T## is temperature, ##S## is entropy and ##W## is work?
In a solid, equilibrium is reached because the potential is a minimum. If you work through the above equations, you can write ## U_{electrostatic}=\frac{1}{2} \beta P^2 ## for some ## \beta ##. If my algebra is correct, ## \beta=\frac{1}{q \chi} ##. With no external electric field, the minimum energy occurs when ## P=0 ##. ## \\ ## From what I learned of solid state physics, there are indeed anharmonic terms in the Hamiltonian, or properties such as thermal expansion would not occur. See also: https://www.docsity.com/en/anharmonic-effects-solid-state-physics-lecture-slides/441110/ ## \\ ## In solid state physics, they often consider the positive nucleus as the item of interest, and consider the forces on the nucleus as it is displaced from its equilibrium position.
Related to Thermodynamic energy and Hamiltonian
1. What is thermodynamic energy?
Thermodynamic energy is a type of energy that is associated with the movement of particles in a system. It is related to the concept of temperature and is used to describe the ability of a system to do work or produce heat.
2. How is thermodynamic energy related to Hamiltonian?
Hamiltonian is a mathematical function that represents the total energy of a system in terms of its position and momentum. In thermodynamics, this function is used to describe the internal energy of a system, which includes both the kinetic and potential energy of its particles.
3. What is the significance of the Hamiltonian in thermodynamics?
The Hamiltonian is a key concept in thermodynamics because it allows us to analyze the behavior of a system and predict how it will change over time. By understanding the Hamiltonian, we can determine the equilibrium state of a system and the direction in which it will naturally evolve.
4. How is thermodynamic energy conserved?
In a closed system, thermodynamic energy is conserved, meaning it cannot be created or destroyed. It can only be converted from one form to another, such as from thermal energy to mechanical energy. This is known as the first law of thermodynamics.
5. Can thermodynamic energy be harnessed for practical use?
Yes, thermodynamic energy can be harnessed for practical use in various ways. For example, it is used to generate electricity in power plants by converting thermal energy into mechanical energy. It is also used in refrigeration and air conditioning systems, where it is used to move heat from one place to another.
  • Classical Physics
