ibysaiyan
- 442
The question is as following:
One litre of an ideal gas, initially at atmospheric pressure, is held at a constant
temperature of 300 K (by maintaining good thermal contact with a thermal reservoir
held at this temperature). The volume is decreased until the pressure doubles.
Calculate how much work is done on the gas. How much heat flows out of the gas?
[tex]W = \int P(V) dV[/tex]
Now I know that for work done in a varying pressure , I must use the following equation:[tex]W = \int P(V) dV[/tex]
where I sub in ideal gas equation for pressure.
[itex]W = nRT\ln{(V0/V)}[/itex] (since it's compression not expansion)
Information that's given : 1 lite of water = 55.5 moles , T = 300k , Pressure 1 : 1x10^5 , pressure 2 : 2x10^5 , Volume one : 0.001 m3 , volume 2 : 5x10^-4 (since p1v1 = p2v2)After having plugged in the numbers.. I get work of 319 joules .
Am I on the right track ? also since this is an isothermal cycle Internal energy stays constant i.e dE =0, So work done = heat out, right ?
