Thermodynamical conservation of energy?
In summary, the heavy box falls from a height of 70m and is slowed by magnets on the surface of the box and copper plates on the tower. The temperature difference between the copper plates decreases as the box falls.
Gavroy
235
There is a tower and a heavy box in it, which weighs 20.000 kg. This box falls down from 70m and after falling 40m(free fall), she is slowed down by magnets on the surface of the box, which interact after falling 40m with copper plates on the tower, which weigh 2.000kg. Then 2 m high, the velocity of the box is 2,77 m/s. Now the question is: What is the change in temperature for the copper plates? Of course friction is neglected!
m1=20.000kg
h1=70m
h2=2m
v=2,77m/s
c(Copper)=385 J/(kg*K)
m2= 2.000kg
Now I thought about solving this by using the law of conservation of energy, since the potential energy at the beginning is equal to the potential energy at the end+ the kinetic energy the box has+the heat that is absorbed by the copper plates:
[TEX] m1 g h1=1/2 m v²+m2 g h2+ m2 c T[/TEX]
But in this case, it would not matter, that the slow down process, does not start until the box has covered these 40m and this information would be redundant. So I think my approach is wrong, but I have no idea, what I am actually doing wrong. Can you help me, please?
You sound right to me. Conservation of energy should work in this problem. Maybe the 40m was thrown in there to confuse people. Or maybe I am too tired and I am misreading something :)
The only reason the height at which the mag field is turned on would make any difference is in the power (the rate at which the energy is lost). Which doesn't seem to be needed for this problem.
thanks for your reply! I will try it this way now.
and otherwise, maybe someone has an idea, why these 40m are important, because our teacher has never given us an information, that is not needed to solve the problem.
Hmm, I don't know if I quite understand the full situation going on here. It depends on how the box is being slowed down. Is it being slowed down purely due to a magnetic interaction, that there is a magnet on the ground for example, then all forces are conservative and the 40m height doesn't matter. If, on the other hand, the box slows down due to electromagnetic induction, this is how the tower roller coasters brake for example, then that is a non-conservative force akin to friction. I think you can say that all the energy goes into ohmic heating, and you're back on track with accounting for all energy in your energy conservation. However, in the electromagnetic induction case, the heat energy term doesn't come in effect until it is 30m from the ground, and you definitely want to factor that aspect in.
Yes, I think you are right, it must be induction, cause there is no other magnet.
But how can I calculate the heat in this case? Can you help me?
If you know the energy at the start of the 30m, and the energy at 2m, you can use conservation of energy just how you outlined it before, at least given that the only extra energy we need to account for is heat. The way you were doing it would be right in this case if you first look at the energy to get to that midpoint
start = mid
U = Um + KEm
mid = end
Um + KEm = Ue+KEe+Q
=>U=Ue+KEe+Q
But this is equal to that what I have written, isn't it?
Yeah, it looks good to me given some assumptions. I just brought up the electromagnetic induction concept because you seemed doubtful about what you were doing. I still don't know if that is a valid assumption to make, that almost all the energy lost is going to heat, so you that's why I placed my stamp of uncertainty on it all.
FAQ: Thermodynamical conservation of energy?
What is the law of thermodynamical conservation of energy?
The law of thermodynamical conservation of energy, also known as the first law of thermodynamics, states that energy cannot be created or destroyed, only transferred or converted from one form to another. This means that the total amount of energy in a closed system remains constant.
How does the law of thermodynamical conservation of energy apply to everyday life?
The law of thermodynamical conservation of energy applies to everyday life in many ways. For example, when we turn on a light bulb, electrical energy is converted into light and heat energy. When we ride a bike, the chemical energy in our body is converted into kinetic energy to move the bike. This law also explains why perpetual motion machines are impossible.
What is an example of a closed system in relation to the law of thermodynamical conservation of energy?
A closed system is a system that does not exchange matter or energy with its surroundings. An example of a closed system is a sealed water bottle. The water and air inside the bottle cannot escape and no outside energy can enter, therefore the amount of energy in the bottle remains constant.
Can the law of thermodynamical conservation of energy be violated?
No, the law of thermodynamical conservation of energy is a fundamental law of physics and has been proven through numerous experiments and observations. It is a universal law that applies to all systems, from microscopic particles to the entire universe.
How is the law of thermodynamical conservation of energy related to the second law of thermodynamics?
The second law of thermodynamics states that the total entropy (disorder) of a closed system can never decrease over time. This is directly related to the law of thermodynamical conservation of energy, as energy naturally tends to disperse and become more evenly distributed, leading to an increase in entropy. The second law explains why perpetual motion machines are impossible, as they would violate the law of thermodynamical conservation of energy and decrease entropy.
