Thermodynamics and Open Systems
In summary, the conversation revolves around the application of the laws of thermodynamics to open systems. The question is raised whether the Earth, as an open system receiving energy from the sun, is an exception to these laws. The concept of closed and isolated systems is discussed, and the idea that ultimately everything is part of one big closed and isolated system, the universe, is introduced.
seeker12
Two caveats:
One, I may or may not be posting my questions in the correct section of this forum. If not, then please kindly direct to where I should post it.
Two, I studied English in college. I am not entirely ignorant of the sciences, but they are certainly not my area of expertise. So, if my questions seem elementary or naive, you can understand why.
My questions:
If the laws of thermodynamics are or were formulated in reference to closed systems, with "closed" being the key word, then how do they apply to "open" systems?
In this context, I take a closed system to be one with a finite amount of energy; there is no energy entering the system and no energy exiting the system.
Would the Earth then be an example of an open system, because energy in the form of sunlight is constantly entering the system? If not, then what would be a good example of an open system?
Many thanks ...
Science news on Phys.org
seeker12 said:
Two caveats:
My questions:
Many thanks ...
A closed system is one of constant mass, not constant energy.
To illustrate Chestermiller's point, the first law of thermodynamics relates the internal energy of a system to the heat and work entering or leaving it. The internal energy can vary.
The laws were originally derived for systems of constant mass (such as gases trapped in cylinders), but can be - and have been - adapted for use with open systems (i.e. systems with particle numbers that can vary owing to particles entering or leaving through real or imaginary system boundaries).
A closed system is defined as a system that does not interact with other systems. So, yes you are right, Earth is not a closed system because is absorbs energy from the sun and radiates energy to space.
This is not correct. You are talking about an isolated system, which is different from a closed system. Here is a good starting point.
http://en.wikipedia.org/wiki/Thermodynamic_system
I stand corrected.
My thanks for your responses. I chose to post my question here because I was hoping to stay away from Wikipedia (which is a wonderful resource that I use regularly, but I don't like to rely on it as a single source of information).
My question arises because of a recent debate between myself and a couple of my friends. The topic of the debate actually concerned metaphysics more than physics. One of my friends invoked the second law of thermodynamics in relation to the subject, and my other friend objected to his doing so, claiming that the subject in question was an open system, not a closed system, and therefore the law would not apply.
For common and uncontroversial questions, it is usually good. But good to verify.
Hit him with this: system definition is arbitrary/a matter of convenience. Ultimately, everything is part of one big closed and isolated system: the universe. So there is no escape from the laws of thermodynamics.
Related to Thermodynamics and Open Systems
What is thermodynamics?
Thermodynamics is a branch of physics that deals with the study of energy and its transformation from one form to another.
What is an open system?
An open system is a thermodynamic system that can exchange both matter and energy with its surroundings.
What is the first law of thermodynamics?
The first law of thermodynamics, also known as the law of conservation of energy, states that energy cannot be created or destroyed, only transferred or converted from one form to another.
What is the second law of thermodynamics?
The second law of thermodynamics states that the total entropy of an isolated system will always increase over time, or remain constant in ideal cases where the system is in a steady state or undergoing a reversible process.
What is the difference between an open system and a closed system?
A closed system is a thermodynamic system that can exchange energy, but not matter, with its surroundings. In contrast, an open system can exchange both matter and energy with its surroundings.
