Thermodynamics: Calculating Final Pressure from Volume Differential
In summary, we can use the ideal gas law and density equation to calculate the final pressure of liquid water that is heated and compressed at constant temperature and pressure. The final pressure is 311.1 bar.
waters
29
Liquid water, initially at 25.00 °C & 1.000 bar is heated at constant
pressure to 95.00 °C, then is compressed at constant temperature to a final
pressure at which the volume is the same as the original volume (25.00 °C,
1.000 bar). Calculate the final pressure.
M = 18.015 g mole-1.
At 25.00 °C & 1.000 bar: ρ = 0.9970 g cm-3.
Data from text:
β = 2.04 x 10-4 K-1. κT = 45.9 x 10-6 bar-1.
dV = (∂V/∂T)dT + (∂V/∂P)dP
β = (∂V/∂T)/V (Thermal Expansion)
κT = -(∂V/∂P)/V (Isothermal Compressibility)
You rearrange the equation: dV = (∂V/∂T)dT + (∂V/∂P)dP and solve for the differentials by multiplying β and κT by the volume. The only problem is, I don't know how to get the volume. Should you assume dV ≈ 0 for liquids? The answer is 311.1 bars.
Hello! Thank you for your post. To solve this problem, we can use the ideal gas law, PV = nRT, where P is pressure, V is volume, n is the number of moles, R is the gas constant, and T is temperature. We can also use the density equation, ρ = m/V, where ρ is density, m is mass, and V is volume.
First, we can calculate the initial volume of the water using the density given in the problem. We know that ρ = 0.9970 g/cm^3 and M = 18.015 g/mol, so we can calculate the number of moles, n, as follows:
n = m/M = (1 g)/(18.015 g/mol) = 0.0555 mol
Next, we can use the ideal gas law to calculate the initial volume at 25.00 °C and 1.000 bar:
V1 = (nRT1)/P1 = [(0.0555 mol)(0.08314 L bar/mol K)(298 K)]/1.000 bar = 1.46 L
Now, we can use the ideal gas law again to calculate the final pressure at the same volume and temperature:
P2 = (nRT2)/V1 = [(0.0555 mol)(0.08314 L bar/mol K)(368 K)]/1.46 L = 311.1 bar
Therefore, the final pressure is 311.1 bar. I hope this helps!
Related to Thermodynamics: Calculating Final Pressure from Volume Differential
What is thermodynamics?
Thermodynamics is the branch of physics that deals with the relationships and conversions between heat, work, and energy in a system.
How is final pressure calculated from a volume differential?
Final pressure can be calculated using the ideal gas law, which states that pressure is directly proportional to the ratio of the number of moles of gas to the volume and the temperature of the gas. By knowing the initial volume, initial pressure, and final volume, the final pressure can be calculated using the ideal gas law equation.
What is the ideal gas law equation?
The ideal gas law equation is PV = nRT, where P is the pressure in pascals, V is the volume in cubic meters, n is the number of moles of gas, R is the universal gas constant, and T is the temperature in Kelvin.
What are the units of pressure and volume in thermodynamics?
The standard unit of pressure in thermodynamics is pascal (Pa), and the standard unit of volume is cubic meter (m3). However, other units such as atmospheres (atm), millimeters of mercury (mmHg), and liters (L) are also commonly used.
What is the significance of calculating final pressure from volume differential?
The calculation of final pressure from volume differential is important in understanding the behavior of gases under different conditions. It allows scientists to predict the changes in pressure when the volume of a gas is altered, and vice versa. This is crucial in various fields such as chemistry, engineering, and meteorology.
