Thermodynamics: closed system problem
In summary: Therefore, in summary, the final temperature remains at 400 K and the final pressure is 3 bar. This is because the piston is frictionless and thermally conducting, allowing for the heat to be evenly distributed and the ideal gas law to be applied to determine the final pressure.
jofree87
38
As shown in the figure attached, an insulated box is initially divided into halves by a frictionless, thermally conducting piston. On one side of the piston is 1.5 m^3 of air at 400 K, 4 bar. On the other side is 1.5 m^3 of air at 400 K, 2 bar. The piston is released and equilibrium is attained, with the piston experiencing no change of state. Employing the ideal gas model for the air, determine:
a) the final temperature, in K.
b) the final pressure, in bar.
The answer provided by my professor for temperature is 400 K, and the final pressure, 3 bar. I would like to know how is this problem solved?
Thank you. Solution:a) The final temperature in this case remains at 400 K since the piston is frictionless and thermally conducting, and therefore the heat produced due to work done by the internal forces in the system (due to the pressure difference) will be uniformly distributed to both sides of the piston. Thus, the temperatures of both sides remain the same.b) To determine the final pressure, we use the ideal gas law:PV = nRTWhere P is the pressure, V is the volume, n is the number of moles of gas, R is the universal gas constant, and T is the temperature.Since both sides of the piston are initially at the same temperature and volume, we can rewrite the equation as follows:P1V1 = P2V2where P1 and V1 are the pressure and volume on one side of the piston, and P2 and V2 are the pressure and volume on the other side.We know that V1 = V2 = 1.5 m^3. We also know that P1 = 4 bar and P2 = 2 bar. Substituting these values into the equation above, we get:4(1.5 m^3) = 2(1.5 m^3)Solving for P2 gives us a final pressure of 3 bar.
FAQ: Thermodynamics: closed system problem
What is a closed system in thermodynamics?
A closed system in thermodynamics is a physical system that does not exchange matter with its surroundings. This means that the system is isolated and does not allow any matter to enter or leave.
What is the closed system problem in thermodynamics?
The closed system problem in thermodynamics refers to the challenge of accurately predicting the behavior of a closed system. This is because closed systems are affected by internal changes, such as energy transfer and chemical reactions, which can make it difficult to determine the final state of the system.
How is energy conserved in a closed system?
In a closed system, energy is conserved through the first law of thermodynamics, which states that energy cannot be created or destroyed, only transferred or converted from one form to another. This means that the total energy of a closed system will remain constant, even if it undergoes internal changes.
Can a closed system reach a state of thermodynamic equilibrium?
Yes, a closed system can reach a state of thermodynamic equilibrium, where all internal changes have ceased and the system is in a stable, unchanging state. At this point, the system's energy is evenly distributed and there is no net transfer of energy between the system and its surroundings.
How does the second law of thermodynamics apply to closed systems?
The second law of thermodynamics states that the total entropy (measure of disorder) of a closed system will always increase over time. This means that even if a closed system reaches a state of equilibrium, it will still experience an overall increase in entropy due to internal changes.
