Thermodynamics conceptual question(for advanced people)?
In summary: The ratio of energy transformed into heat vs pressure is not constant through compression, as it depends on the specific conditions of the compression (adiabatic or with heat flow). In summary, the equation for temperature as a function of volume in an adiabatic compression is T_fV_f^{\gamma-1} = T_iV_i^{\gamma-1} = \text{Constant}. If heat is added, the first law must be used to calculate the change in internal energy, which is dependent on the initial and final temperatures and the specific heat capacity. The ratio of energy transformed into heat vs
StarDust563
If you compress a gas in a piston(a monoatomic perfect gas for instance), what is the equation that gives you the temperature of the gas or amount of heat introduced in the gas vs the volume of the gas?
And what is the ratio of energy that is transformed into heat vs into pressure? Is it constant through compression?
thanks a lot
Science news on Phys.org
If this is an adiabatic compression (no heat flow into or out of the gas), then:
[tex]T_fV_f^{\gamma-1} = T_iV_i^{\gamma-1} = \text{Constant}[/tex]
If heat is added, you have to know the heat flow and the work done by/on the gas and use the first law:
[tex]\Delta U = nC_v\Delta T = \Delta Q - W[/tex] where W is the work done by the gas (which is the negative of the work done on the gas - ie. in compressing the gas)
AM
FAQ: Thermodynamics conceptual question(for advanced people)?
What is the difference between heat and temperature?
Heat refers to the transfer of energy from one object to another due to a difference in temperature. Temperature, on the other hand, is a measure of the average kinetic energy of the particles in a substance. In other words, heat is the energy being transferred, while temperature is a measure of how much energy the substance contains.
What is the second law of thermodynamics?
The second law of thermodynamics states that in any spontaneous process, the total entropy of the universe will always increase. This means that energy will always tend to disperse and become more disordered over time.
What is the difference between an open and closed system?
An open system is one in which both matter and energy can be exchanged with the surroundings. In a closed system, only energy can be exchanged, while no matter can enter or leave the system.
What is the Carnot cycle?
The Carnot cycle is a theoretical thermodynamic cycle that describes the most efficient way to convert heat into work. It consists of four stages: isothermal expansion, adiabatic expansion, isothermal compression, and adiabatic compression.
How does thermodynamics relate to everyday life?
Thermodynamics plays a role in many everyday processes, from cooking and refrigeration to car engines and power plants. Understanding thermodynamic principles can help us optimize these processes and make them more efficient. It also helps explain why certain things happen, such as why hot coffee cools down over time.
