Thermodynamics, enthelpy change for steam
In summary: No, the entropy values at entrance and exit are pretty close, but not identical. However, the difference in entropy should only affect the thermodynamic efficiency of the turbine.
zulfiqar6
Steam at 200psia and 600 *F [state 1] Enters a turbine through a 3-inch-diameter pipe with a velocity of 10(ft)/(s). The exhaust from the turbine is carried through a 10-inch-diameter pipe and is at 5psia and 200 *F [state 2]. What is the power output of the turbine?
H1 = 1,322.6(Btu)/lbm
H2 = 1148.6(Btu)/lbm
V1 = 3.058ft^3 / lbm
V2 = 78.14ft^3 / lbm
dH = (u^2 / 2*gc) + Q + W
dH = -174Btu/lbm
174Btu/lbm = du/2gc + Q + W
mass flowrate = (A1*u1) / V1 == 0.1605 lbm/s
final velocity u2 = (m * V2) / A2 = 23.0 ft/s
du = 13ft/s
What do I do now? How do I calculate Q and W?
there are tables at the back of the book with properties of steam for various temperatures and pressures...some of the example problems I looked at make use of that, but I'm not quite sure how that helps here.
In the equation you are using (correct choice), W is the shaft work (i.e., the work done by the turbine per pound of steam =-work done on the turbine, per pound of steam). This is what you are solving for. Probably, a reasonable assumption is that the turbine operates adiabatically, so that Q = 0. You have already made a pretty good start at solving this problem.
Chet
But then what does the temperature change have to do with it? How can Q equal 0 when there's a temperature change? I don't have to use the temperatures in my calculations at all because Q=0?
Each pound of steam is expanding as it passes through the turbine and does work on the rotor. So its temperature is decreasing. You use the temperatures to get the inlet and outlet enthalpies, and thus the change in enthalpy. Q can, of course, be zero even if there is a temperature change (as you have already seen earlier in your thermo course).
The Q value is, I believe, heat added or lost to the surroundings. The turbine casing and steam piping will be insulated to minimize any heat transfer from the equipment to its surroundings.
The assumption of isentropic operation of the turbine may not necessarily be true. Since you have entrance and exit conditions for the steam, a check of the steam tables should provide entropy values at these points.
(Note: I checked with printed tables online and found that the turbine is not operating isentropically).
You know the change in enthalpy per pound of steam, and you know the flow rate of the steam in pounds per second. You can find the work equivalent of the change in enthalpy and then use the flow conditions to find out the rate at which work is being done by the turbine.
Hi SteamKing. I hope you didn't think that I was implying isentropic operation. All I said was that the operation was probably close to adiabatic, so that Q would be essentially zero.
The OP should check the change in kinetic energy. I don't think that this will make a significant contribution, but it should at least be considered.
Chet
Chet
Since this is a First Law type analysis, the Q will indicate the amount of heat exchanged across the boundary of the control volume around the turbine. In practical terms, Q is always minimized, if not eliminated entirely, by insulating the equipment, so that the heat in = work out + heat out.
Incidentally, that kinetic energy term in the original equation should really be the change in kinetic energy, and it should be on the same side of the equation as the ΔH. I still think that it going to turn out to be negligible compared to the enthalpy change.
Chet
So I solved it assuming adiabatic (Q=0) and assuming the kinetic energy term is negligible. But out of curiosity, how would I solve this problem if it WASN'T adiabatic? What if the turbine was transferring heat?
Then you would need additional information such as the detailed geometry of the housing and the thickness and thermal characteristics of the insulation. You would also need to know the temperature outside the housing. You would be looking at conductive heat transfer through the insulation, and possible convective heat transfer from the outside surface of the insulation to the surrounding air.
I suggest that you calculate the kinetic energy term just to see how if compares with the enthalpy change.
FAQ: Thermodynamics, enthelpy change for steam
What is thermodynamics?
Thermodynamics is the branch of science that deals with the relationship between heat, work, and energy in a system.
What is enthalpy change for steam?
Enthalpy change for steam refers to the amount of heat energy absorbed or released during the transition of water to steam at constant pressure.
How is enthalpy change for steam calculated?
Enthalpy change for steam is calculated using the equation ΔH = mCΔT, where ΔH is the enthalpy change, m is the mass of the substance, C is the specific heat capacity, and ΔT is the change in temperature.
What factors can affect the enthalpy change for steam?
The enthalpy change for steam can be affected by factors such as pressure, temperature, and the physical properties of the substance.
What is the significance of enthalpy change for steam?
The enthalpy change for steam is significant because it is a measure of the energy required for the phase transition of water to steam, which is important in various industrial processes and power generation.
10K
