kwak
- 1
From a previous post in this forum, unfortunately the thread is closed for answers otherwise I would have posted it there: https://www.physicsforums.com/threads/thermodynamic-filling-of-tank-matlab.479112/
A 70 ft3 rigid insulated tank contains air at 14.7 psia and 80 º F. The tank is connected to a supply line through a valve. Air is flowing in the supply line at 75 psia and 80 º F. The valve is opened, and air is allowed to enter the tank until the pressure in the tank reaches the line pressure, at which point the valve is closed. The diameter of the connecting pipe is 1 inch.
Write a computer program to model the pressurization process in the tank. The computer program will calculate the pressure, temperature, mass flowrate into the tank and resident mass during the process. Determine the final temperature, mass of air in the tank and time required to pressurize the tank.
mass flow rate mdot=A1*sqrt(((2*k)/(k-1))*P1*g*rho1*(P2/P1)^(2/k)*(1-(P2/P1))^(k-1/k))
where k = Cp/Cv
I modeled a comparable situation in SI units using vanderWaals EOS and I would like to compare it to the results from the thread mentioned above. However I do not know where this equation for the mass flow rate came from. Does someone recognize it?[/B]
