Thermodynamics - find entropy in isovolumetric system
In summary, a well-insulated rigid tank initially contains 7 kg of a saturated liquid-vapor mixture of water at 150 kPa, with 3/4 of the mass in the liquid phase. An electric resistance heater is turned on and kept on until all the liquid is vaporized. The entropy change of the system during this process can be determined using tables to find the specific entropy of the initial and final states. The final state is pure saturated water vapor, with a final temperature and pressure that can be calculated based on the initial conditions. The final entropy can also be calculated using the specific entropy of the final state. Some additional considerations, such as the specific volume and average specific volume of the initial state, as well as the
Feodalherren
605
A well-insulated rigid tank contains 7 kg of a saturated liquid-vapor mixture of water at 150 kPa. Initially, three-quarters of the mass is in the liquid phase. An electric resistance heater placed in the tank is now turned on and kept on until all the liquid in the tank is vaporized. Determine the entropy change of the system during this process.
Using tables I found S1 = 2.88105 kJ/kg K
by s=Sf + xSfg
Since it finishes at the saturated vapor line the final entropy should be Sg @ 111.15 °C because this is the saturation temperature which I interpolated to 7.22369 kJ/kg K.
For some reason the final value is completely wrong. The books gets it to 6.7296 for some weird reason.
My thought was that if the box has a constant volume, the pressure is increasing so we can't use Tsat to find our final entropy. In other words - this process is not isothermal. Is this assumption correct?
by s=Sf + xSfg
If you have 7 kg of water, and, initially, 3/4 is liquid, how many kg of liquid water do you have initially, and how many kg of water vapor do you have initially?
What is the specific volume of the liquid? What is the specific volume of the vapor? What is the average specific volume of the combination? Does this average specific volume change if the volume of the tank is constant?
What is the specific entropy of the liquid water initially? What is the specific entropy of the water vapor initially? What is the total entropy of the initial combination of liquid water and water vapor?
If you have pure saturated water vapor in the final state with the same specific volume as the original combination of liquid water and water vapor, what is the final temperature and pressure? What is the final mass of the water vapor? What is the final specific entropy of the water vapor? What is the final entropy?
Chet
Related to Thermodynamics - find entropy in isovolumetric system
1. What is thermodynamics?
Thermodynamics is a branch of physics that deals with the study of the relationship between heat and other forms of energy, and how they affect matter. It also involves the behavior of systems in relation to their surroundings.
2. What is entropy?
Entropy is a measure of the disorder or randomness of a system. It is a thermodynamic quantity that increases with the amount of energy dispersed in a system, or the number of possible ways that energy can be distributed among the particles of a system.
3. How is entropy calculated in an isovolumetric system?
In an isovolumetric system, where the volume remains constant, the change in entropy can be calculated using the formula ΔS = Q/T, where ΔS is the change in entropy, Q is the heat transferred, and T is the temperature in Kelvin. This equation is known as the Second Law of Thermodynamics.
4. How does entropy relate to the Second Law of Thermodynamics?
The Second Law of Thermodynamics states that the total entropy of a closed system will always increase over time. This means that energy will naturally disperse and become more random, leading to an increase in entropy. The relationship between entropy and the Second Law is crucial in understanding the behavior of systems in nature.
5. What are some real-life examples of entropy?
Some common examples of entropy in everyday life include the melting of ice cubes, where the solid ice particles become more disordered as they melt into liquid water. Another example is the rusting of metal, where the orderly arrangement of metal atoms is disrupted as they react with oxygen in the air. Both of these processes result in an overall increase in entropy.
10K
