Thermodynamics flow processes,
In summary, the conversation discusses the flow of air into a compressor and the resulting changes in pressure and temperature. The problem also mentions the heat lost and work transfer in the compressor, and assumes that air behaves as a perfect gas with small velocities at the inlet and outlet. The conversation ends with a request for clarification on the relevant equations and topics covered in the thermodynamics class.
TheRedDevil18
408
Air at 1 bar and 20°C flows steadily at a rate of 2 m^3/min into a compressor. It leaves at a
pressure of 15 bar and 120°C. The heat lost from the compressor is 10% of the work transfer to it.
Find these work and heat transfers, assuming that air behaves as a perfect gas and the velocity at
the inlet and outlet is small.
I don't know where to start with this problem
You don't know where to start? Can you even write down a relevant equation? What are you covering in your Thermodynamics class right now?
Chet
Related to Thermodynamics flow processes,
What is thermodynamics?
Thermodynamics is a branch of physics that studies the relationship between heat, energy, and work. It explains how these factors interact and change in different systems.
What are flow processes in thermodynamics?
Flow processes in thermodynamics refer to the transfer of heat and/or work between a system and its surroundings. This can occur through various methods such as conduction, convection, and radiation.
What is the first law of thermodynamics?
The first law of thermodynamics, also known as the law of conservation of energy, states that energy cannot be created or destroyed, but can only be transferred or converted from one form to another.
What is the second law of thermodynamics?
The second law of thermodynamics states that the total entropy of a closed system will always increase over time, and that it is impossible to convert heat completely into work without some energy being lost as waste heat.
What are the different types of thermodynamic processes?
The three main types of thermodynamic processes are isothermal, adiabatic, and isobaric processes. Isothermal processes involve constant temperature, adiabatic processes involve no heat transfer, and isobaric processes involve constant pressure.
  • Mechanical Engineering
