Thermodynamics: Free Energy Confusion
In summary, the student is trying to understand thermodynamics and enthalpy and free energy. They are learning from a text by Schroeder, and they understand that enthalpy is the total energy required to create a system with internal energy out of nothing, that enthalpy change is the amount of work needed to increase the internal energy of a system, and that Gibbs' free energy is the total energy required to create a system with internal energy while taking into account the amount of heat that can be drawn from the environment. Helmholtz free energy is the same as Gibbs' free energy, but it includes compression work.
WWCY
479
Hi all, I'm having quite a big problem trying to understand the concept of enthalpy and free energy. I feel that a good way to sort this out is to write out what I understand about these things and have people correct me. Thanks in advance for any assistance.
I'm learning thermodynamics from Schroeder's text.
Enthalpy, ##H = U + PV##
At constant pressure, Enthalpy is the total energy required to create a system with internal energy ##U##out of nothing. This total energy is the sum of the system's internal energy and the compression work needed to create space for the system.
Enthalpy change, ##\Delta H = \Delta U + \Delta PV = \Delta Q + \Delta W_{other}## where ##\Delta U = \Delta Q + \Delta W_{other}##
At constant pressure, ##\Delta H## is the amount of work needed to increase the internal energy of a system while doing more compression work to create even more space for it.
It also says that I can only retrieve energy in the form of heat and non-compression work by drawing from a system's enthalpy.
Gibbs' Free Energy ##G = U - TS + PV##
At constant pressure and temperature, ##G## is the total energy required to create a system with internal energy ##U## out of nothing. This total energy is the sum of the system's internal energy and the compression work needed to create space for the system. However, it also takes into account the amount of heat ##TS_{final}##we can draw from the environment while building the system.
Gibbs' Free Energy Change##\Delta G = \Delta U - T\Delta S + P\Delta V = \Delta W_{other} + \Delta Q - T\Delta S ##
At constant pressure and temperature, ##\Delta G## represents the amount of energy needed to increase a system's internal energy while doing compression work on its surroundings. However, we can offset the environment's contribution of heat by deducting ##T\Delta S##. It also shows that we can draw ##\Delta W_{other}## at most (quasistatic change), by decreasing a system's ##G## since ##\Delta Q \leqslant T\Delta S ##.
Question: Why is ##\Delta Q \leqslant T\Delta S ## the case?
Helmholtz Free Energy ##F = U - TS##
At constant temperature, this represents the amount of energy needed to create a system with internal energy ##U##, while offsetting environmental heat contributions ##TS_{final}##.
Question: Why does this not include compression work ##PV##? While I understand that pressure is not taken to be constant, do we not need to do work to create space for the system?
Helmholtz Free Energy Change ##\Delta F = \Delta U - T \Delta S = \Delta Q + \Delta W_{all} - T\Delta S##
This tells us the amount of work needed to increase a system's internal energy while taking into account environmental contributions of heat ##T\Delta S##. It also tells us that should we draw from a system's ##F##, we can obtain energy in the form of ##\Delta W_{all}## at most (quasistatic changes). ##\Delta Q \leqslant T\Delta S ##
Question: Again, not too sure why ##\Delta Q \leqslant T\Delta S ## and why no compression-work term is included.
Please feel free to add on points that are important and of course, correct any misconceptions.
Thanks very much in advance!
Would anyone be so kind as to assist? Thank you!
Related to Thermodynamics: Free Energy Confusion
1. What is the difference between enthalpy and entropy?
Enthalpy is a measure of the total energy in a system, while entropy is a measure of the disorder or randomness in a system. Enthalpy typically increases in exothermic reactions, while entropy increases in endothermic reactions.
2. How is free energy related to thermodynamics?
Free energy is a measure of the energy available to do work in a system. It is related to thermodynamics through the equation ΔG = ΔH - TΔS, where ΔG is the change in free energy, ΔH is the change in enthalpy, T is the temperature in Kelvin, and ΔS is the change in entropy.
3. What is the significance of Gibbs free energy?
Gibbs free energy is a measure of the spontaneity of a reaction. If ΔG is negative, the reaction is spontaneous and can occur without the input of external energy. If ΔG is positive, the reaction is non-spontaneous and will require an input of energy to occur.
4. Can free energy be created or destroyed?
No, according to the first law of thermodynamics, energy cannot be created or destroyed, only transferred or converted. This applies to free energy as well.
5. How can free energy be used in practical applications?
Free energy can be used to predict the spontaneity of a reaction, determine the conditions necessary to drive a reaction, and optimize industrial processes to be more efficient. It also plays a crucial role in biochemical reactions and cellular metabolism.
