Thermodynamics -- Free expansion of gas
In summary, the conversation discusses a setup with two chambers separated by a stop cock, one containing gas and the other vacuum. The question is raised about the work done by the gas when the stop cock is removed and the gas expands into the vacuum. It is explained that since there is no opposing force, the work done by the gas is zero. The formula for work done by gas is discussed and it is pointed out that the pressure of the gas is not constant in this scenario. The concept of free expansion is also mentioned. The conversation then delves into further questions about the pressure and temperature of the gas, the force exerted by the gas, and the role of viscosity in an ideal gas.
Vibhor
971
40
We have 2 (insulated) partitions, one with the gas, another vacuum, separated by a stop cock. We remove the cock, letting the gas expand into vacuum .
I understand that since there is no opposing force on the expanding gas ,the work done by the gas is zero .
But work done by gas is given by PgasΔV . Now Pgas≠0 and ΔV≠0 , so PgasΔV≠0 , so mathematically how is work done by gas zero ?
Please help me clear this doubt ?
Science news on Phys.org
Well, you could say that there has been some work done, because the centre of mass of the gas has moved, but that can easily conceptually be taken care of by arrangement of the gas container and the vacuum container.
The simple explanation is that Pgas is the pressure on the pressurized side, right. If a little bit of that gas goes through the stop cock does it encounter a resistance from the vacuum? What would the pressure of that little bit of gas be then? Certainly not Pgas.
Normally, when one calculates the work of a gas there is an opposing resistant force on the other side of the piston, so that the expansion is controlled. What you are interested in a lot of times is the value of that force, either with an expansion or compression, and one way to do that is through the P deltaV formula.
Are the two chambers insulated from one another, or are they in thermal contact with one another? Does the gas escape very rapidly, or does it seep through the stopcock?
Chet
Thanks for your response.
Right.
If not Pgas ,then what is the pressure ?
Is work of a gas different from the standard definition of work in physics i.e FΔx ? I am trying to understand the work done by gas using this standard definition .
Thanks for replying.
Chet
Yes,the chambers are thermally insulated . I guess ,the gas escapes very rapidly . Does gas seeping through the stopcock make any difference ? I am going with the standard setup taken to explain free expansion.
Usually "free expansion" is shown by unplugging a hole in the barrier and letting the gas leak out and expand into the vacuum (or by suddenly removing the barrier).
Ultimately no unless the two chambers are thermally isolated from one another.
What you're looking at is the same thing as if you have a cylinder, with the two chambers separated by a massless frictionless piston. And, at time zero, you suddenly release the piston, and allow the system to re-equilibrate.
Now, my questions to you are:
1. in this situation, is the pressure and temperature of the gas uniform within the cylinder, or does it vary with spatial position during the rapid deformation?
2. If the piston is massless and frictionless, from Newton's 2nd law, if the pressure on one side of the piston is zero, what does this tell you about the force per unit area exerted by the gas on the other side of the piston.
3. If the force per unit area exerted by the gas on the piston is zero, what is the work done by the gas?
4. Is the viscosity of an ideal gas zero?
5. In a rapidly deforming fluid, are the stresses simply isotropic pressure, are are there viscous contributions to the stresses (i.e., the forces per unit area)?
Chet
Are you saying a "yes" or a "no" to whether the two situations are different ? By the way the chambers are thermally insulated .
Ok
I think the pressure and temperature of the gas are uniform within the left partition (assuming the gas is initially in left partition) but vary when it moves to the right partition .
It has to be zero . I think here lies the problem in my thinking :rolleyes:. Isn't the pressure at the left side of piston Pgas (at the left interface)?
Zero . But Isn't force F =Pgas A (Area of piston) ? The PA term is non zero .
What I do not understand is that how is F=0 even when Pgas ≠0 ?
Chet
Sorry . No idea . I am looking for a high school level explanation.
If the two chambers are thermally isolated and the gas seeps through the stopcock, there is a significant difference between this and free expansion.
Remember, we are now talking about the case where a frictionless massless piston separates the two chambers, and there is never any gas on the vacuum side. In any event, during the rapid gas expansion that occurs, the temperature and pressure are not uniform within the gas, until the final equilibrium state is attained. This is partly because the gas has distributed mass, and different parts of the gas are experiencing different accelerations and expansion rates. And the different expansion rates also cause the temperature to vary spatially.
No. Basically, what is happening is that the rapid movement of the piston away from the bulk of the gas affects the rate of momentum transfer from the gas to the piston. Only a negligible fraction of the gas molecules in the vicinity of the interface actually strike the piston (just enough to keep the "massless" piston moving).
You just said that the force of the gas on the piston has to be essentially zero.
The rapid movement of the piston away from the gas modifies the momentum transfer at the piston face such that only a negligible fraction of the molecules actually strike the "massless" piston.
Likes Vibhor
Vibhor said:
T
No, it isn't. Even if the partitions would be filled by a gas under the same pressure, the work would be zero. The point is that the relevant area is the area perpendicular to the displacement Delta x. If your cock is e.g. a thin metal plate, then this area is negligible. The work done on the piston is in deed p Delta V, but Delta V is not the volume of the second partition, but the volume of your metal plate, which is negligible in idealized settings.
What about the case of massless piston ? There area of the piston face is not negligible .
Why is F=0 despite non zero value of PgasA ?
There is no really massless piston. A very light piston will get accelerated more than a heavier piston, but its final kinetic energy will be the same.
Remember, we are now talking about the case where a frictionless massless piston separates the two chambers, and there is never any gas on the vacuum side. In any event, during the rapid gas expansion that occurs, the temperature and pressure are not uniform within the gas, until the final equilibrium state is attained. This is partly because the gas has distributed mass, and different parts of the gas are experiencing different accelerations and expansion rates. And the different expansion rates also cause the temperature to vary spatially.No. Basically, what is happening is that the rapid movement of the piston away from the bulk of the gas affects the rate of momentum transfer from the gas to the piston. Only a negligible fraction of the gas molecules in the vicinity of the interface actually strike the piston (just enough to keep the "massless" piston moving).
Are you suggesting that Pgas is uniform until the piston is held fixed and once it is released Pgas is no longer uniform .The pressure at the left interface is essentially zero i.e Pgas,left interface = 0 which makes F = ( Pgas,left interface )( A ) = 0 ??
Is it correct ?
Is it correct ?
Yes.
Likes Vibhor
The nice thing with thermodynamic is that results don't depend on details of the process. You can also consider a massive piston. It will speed up and gain kinetic energy equal to ##p\Delta V##. But finally it wil choque against the wall of the container and the kinetic energy will be transformed back into internal energy of the gas so that it's change in the end is zero.
What I had in mind in my earlier post was a plate which is pulled out through a slid.
Chestermiller said:
Yes.
Thank you so much :smile: .I was really struggling with the concept of free expansion.
Please help me clear another doubt .
Why do we relate temperature to only average translational kinetic energy of the molecules , and not to the internal energy of the molecules ? In case of monoatomic molecules ,it makes sense as the internal energy comprises only translational KE .
But what if we consider diatomic molecules. There we have rotational energy as well .The RKE also depends on the temperature .
So why do we say that temperature is related to only translational KE ?
Again does that mean if two substances having same translational KE of molecules but different internal energy , no heat would flow between them ?
Related to Thermodynamics -- Free expansion of gas
1. What is the concept of free expansion in thermodynamics?
In thermodynamics, free expansion refers to the process in which a gas expands into a vacuum without any external work being done on the system. This means that there is no change in temperature, pressure, or volume of the gas during the expansion.
2. How is the free expansion of gas different from other types of expansion?
In other types of expansion, such as isothermal or adiabatic expansion, there is a change in one or more properties of the gas, such as temperature or pressure. In free expansion, however, there is no change in any of these properties.
3. What is the reason for the lack of change in temperature during free expansion?
During free expansion, the gas molecules are expanding into a vacuum and there is no external pressure or energy being applied to the system. This means that there is no transfer of heat, and therefore no change in temperature.
4. Can the free expansion of gas be reversed?
No, the free expansion of gas is an irreversible process. This is because there is no work being done on the system, so there is no way to reverse the expansion and compress the gas back to its original state.
5. How does the concept of entropy relate to the free expansion of gas?
The free expansion of gas is a spontaneous process, meaning it occurs without any external influence. This increase in disorder and randomness is a result of the increase in entropy, which is a measure of the system's disorder. In free expansion, the entropy of the gas increases as it expands into a larger volume.
  • Thermodynamics
  • Thermodynamics
