Thermodynamics: Freezing Point Depression
In summary: The key point is that as long as there is some solvent left, the solution still can be further cooled. When all the solvent freezes, the temperature of the solution will start dropping below the freezing point. So what is happening is that the solution is being cooled and freezing point is changing, until all the solvent is frozen. Then the temperature will start dropping below the freezing point. In summary, the cryoscopic constant of water is used to calculate the molality of a nonvolatile impurity in a solution. In the given scenario, 200 g of ethylene glycol is dissolved in 1.00 L of water at 25°C, resulting in a molality of 5 molal. When the solution is chilled to -25
theow
200 g of ethylene glycol (HOCH2CH2OH) is dissolved in 1.00 L of water at 25°C.
The cryoscopic constant of water is 1.86 °C molal-1.
If the solution is chilled to -25°C, how much ice (in g) will be separated out?
ΔT=Kfm, where Kf is and cryoscopic constant and m is the molality of nonvolatile impurity
Calculated molality = (200/40)/1.00 = 5 molal
Freezing point = -5×1.86 = -9.3°C
But I suppose since the temperature is way lower than the freezing point, all 1000 g of ice would be frozen out?
Thanks a lot:)
No, when the water freezes it is only water that is removed from the liquid phase, so concentration of glycol in solution goes up.
Thanks for your reply, Borek.
But how about the mass of ice? It won't change, will it?
Maybe I'll put it this way. Here's a simpler version:
20.0 g xylitol (C5H12O5) is dissolved in 1.00 L of water at 25°C. The cryoscopic constant for water in 1.86 °C molal-1
If the solution is chilled to -25°C, how much ice (in g) will separate out?​
I hope it's clear to you. Please help:)
I already told you what is happening. Water freezes till concentration of solute grows to the point when rest of the solution is high enough to prevent freezing. Amount of solute doesn't change, amount of solvent does.
hmm... as solute concentration increases, freezing point will continue to decrease. So why would you say
Sorry, it should read
concentration of solute grows to the point when it is high enough to prevent freezing of the rest of the solution
or something like that.
Related to Thermodynamics: Freezing Point Depression
1. What is freezing point depression in thermodynamics?
Freezing point depression is a phenomenon that occurs when the freezing point of a liquid is lowered due to the presence of a solute. This is a result of the solute molecules disrupting the formation of the crystal lattice structure of the solvent, making it more difficult for the liquid to freeze.
2. What causes freezing point depression?
Freezing point depression is caused by the presence of a solute in a solvent. The solute molecules disrupt the bonding between the solvent molecules and prevent them from forming a crystal lattice structure, resulting in a lower freezing point.
3. How is freezing point depression calculated?
The amount of freezing point depression is calculated using the formula ΔT = Kf * m, where ΔT is the change in freezing point, Kf is the freezing point depression constant for the solvent, and m is the molality of the solute in the solution.
4. What is the significance of freezing point depression in everyday life?
Freezing point depression has many practical applications in everyday life. For example, it is used in antifreeze solutions to lower the freezing point of water in car engines, preventing it from freezing in cold temperatures. It is also used in the production of ice cream to create a smoother texture and prevent it from freezing too quickly.
5. How does freezing point depression relate to colligative properties?
Freezing point depression is one of the colligative properties of solutions, which also include boiling point elevation, vapor pressure lowering, and osmotic pressure. These properties depend on the number of solute particles present in a solution, rather than the type of solute. This means that solutions with the same molality will exhibit the same amount of freezing point depression, regardless of the solute used.
16K
17K
9K
