bkh5074
- 1
Air enters a gas turbine at 1600K and exits at 100kPa and 830K. The turbine efficiency is 85%. Determine the turbine inlet pressure?
(I used 3 different methods and got a similar answer. I just don't understand if I was correct in assuming something.)
P=pressure, T=temp, s=entropy
First I used the Relative Pressure to find P1. P1=P2*(Pr1/Pr2)
Second I used the entropy change approximate analysis. (s2=s1 this is what I assumed)
s2-s1=0=cp_avg*Ln(T2/T1)-R*Ln(P2/P1) : Rearrange to solve for P1
Third I used EES which is basically assuming s2=s1, and used T1 and s1 to find P1
First method: P1=P2*(Pr1/Pr2) P2 is given = 100kPa, I used the table to find Pr1 and Pr2 from the Temperatures given. P1=100*(791.2/55.1) = 1435.93kPa
Second method: cp_avg = 1.163, R = 0.287
(1.163)*Ln(830/1600)-(0.287)*Ln(100/P1)
P1=1428.694kPa
Third using EES and I got P1=1435.048kPa
So basically I got the same answer each time, but I wasn't sure if I was correct to assume s2=s1. The problem doesn't specify it's an Isentropic process. Am I to assume that is this case? I don't think that the turbine efficiency is any help either.
Or maybe I'm doing this all totally wrong, My Thermo Professor goes through class so fast and I just try my best to follow along and understand stuff. That's why I joined this forum for some extra help.
Thanks to all,
BKH
