Thermodynamics - Heat of Reaction
In summary, the difference between the heat of reaction at constant pressure and at constant volume can be calculated using the equations ΔHp = ΔUp + PΔV and ΔHv = ΔUv. However, the values of ΔUp and ΔUv may be equal, resulting in the same value for both ΔHp and ΔHv. This is because internal energy is a state function and is not affected by the path taken to reach a given state. Therefore, ΔHp should theoretically be equal to ΔHv, but in practice, they may differ due to experimental errors. ΔH is defined as the enthalpy change of a reaction at constant pressure and temperature, and it is calculated by measuring the heat exchanged during the
Prathamesh
Moved from a technical forum, so homework template missing
Calculate the difference between heat of reaction at constant pressure and at constant volume for following reaction at 298 K.
N2(g)+3H2(g)→2NH3(g)
My attempt ~
At constant pressure
ΔHp=ΔUp+PΔV
At constant volume
ΔHv=ΔUv
∴ΔHp-ΔHv
=ΔUp-ΔUv+ PΔV
And PΔV = ΔnRT
But what to do of ΔUp-ΔUv?
In solution,
For both , at constant pressure and volume
ΔU is mentioned and
ΔU-ΔU =0 is given..
But how is it possible that
ΔUp=ΔUv ?
Well, if you move from one state to another, it doesen't matter how you move. ΔU is zero anyway. So yes, ΔUp = ΔUv.
so, ΔHp should also be equal to ΔHv since it is a state function like internal energy U , why it is not so?
What thermodynamic state variables determine the internal energy of an ideal gas?
If you know this, then you should be able to compare the final internal energy for the constant pressure process with the final internal energy for the constant volume process.
ΔH is defined as the enthalpy change of a reaction at constant pressure and is a state function.. There is no such thing as ΔHp and ΔHv. What you must mean is Qp and Qv.
Likes Prathamesh
ΔH is defined for any process between any two equilibrium states. As you say, H is a state variable. The process need not be at constant pressure in order to calculate ΔH.
Likes Prathamesh
To directly calculate ΔH, I agree the process need not be done at constant pressure. But ΔH is defined as such.
ΔH is not defined as the heat produced at constant pressure and temperature, though it is true that ΔH = q for such a process. H is most rigorously defined as H = U + PV.
Also a helpful note. Performing the reaction at constant temperature does not lead to the same final state as performing the reaction at constant volume. In one case, the final volume will be different and in the other case the final pressure will be different.
Prathamesh said:
At constant volume
ΔHv=ΔUv
Is this true?
ΔH = Δ(U + PV) = ΔU + Δ(PV).
Does Δ(PV) equal 0 for the reaction at constant volume?
Constant pressure and temprature @Ygggdrasil ?
Yes. For tabulated heats of reaction, both the temperature and the pressure are specified to not change between the initial state of pure reactants and for the final state of pure products.
So basically we start at some T,P... do the reaction with reactant A... get product B... bring product B to the same state T,P... measure the heat exchanged... and label this as the heat of the reaction? OK, that actually makes sense.
Yes. That's basically right.
Related to Thermodynamics - Heat of Reaction
What is the definition of "heat of reaction" in thermodynamics?
The heat of reaction, also known as enthalpy of reaction, is the amount of heat energy released or absorbed during a chemical reaction at a constant pressure.
How is the heat of reaction related to the change in enthalpy?
The heat of reaction is equal to the change in enthalpy of the products minus the change in enthalpy of the reactants. It can be represented by the equation: ΔH = Hproducts - Hreactants.
What factors can influence the heat of reaction?
The heat of reaction can be affected by the temperature, pressure, and concentration of reactants and products. It can also be influenced by the physical state of the substances involved, such as solid, liquid, or gas.
How is the heat of reaction measured in a laboratory setting?
The heat of reaction can be measured using a calorimeter, which is a device that can accurately measure the heat released or absorbed during a chemical reaction. The change in temperature of the reactants and products is recorded and used to calculate the heat of reaction.
What is the significance of the heat of reaction in chemical processes?
The heat of reaction is important in determining the energy changes that occur during a chemical reaction. It can also be used to predict the feasibility and spontaneity of a reaction, as well as to optimize reaction conditions for industrial processes.
