Thermodynamics - hot item placed in water
In summary, the initial temperature of the pan in degrees C was 900 J/kg-K, and the initial temperature of the pan in degrees F was 9/5(Tc) + 32. The pan reached thermal equilibrium with the water and had a final temperature of -309 degrees Celsius in kelvin.
portofino
35
A 900 g aluminum pan is removed from the stove and plunged into a sink filled with 12.0 L of water at 19.0 degrees. The water temperature quickly rises to 24.5 degrees.
What was the initial temperature of the pan in degrees C?
What was the initial temperature of the pan in degrees F?
Q_net = 0 where Q is heat
No phase changes involved so no latent heats required
C1 = specific heat capacity, aluminum: 900 J/kg-K
C2 = Specific heat capacity, water: 4.184 kJ/kg-K = 4184 J
Q_net = (C1)(M1)(T) + (C2)(M2)(T2) = 0
where C1 = 900, C2 = 4184, M1 = 900g = 0.9 kg, M2 = 12kg because 1 L water = 1 kg, T = unknown, T2 = 24 - 19 = 5 degrees
Tc = T - 273.15 where Tc is temp in celsius, T is temp in kelvin
Tf = 9/5(Tc) + 32 where Tf is temp in fahrenheit, Tc is temp in celsius
no phase changes involved, no latent heats needed
= (900)(0.9)(T) + (4184)(12)(24-19)
= (900)(0.9)(T) + (4184)(12)(5)
T = -[(4184)(12)(5)] / [(900)(0.9)] = -309 degrees
I assumed that -309 was in kelvin, thus used the above equation to solve for temperature in celsius.
i noticed that the temp was negative, thus decided that since the water temp increased, the temperature had to be positive, thus -309 became 309, and using the kelvin-->celsius conversion i got 36 degrees Celsius which was incorrect?
as for the second part, the initial temp in fahrenheit, i need to solve the first part to get it.
what did i do wrong? it seems like a straightforward problem, i think i missed something.
thanks
Hi portofino,
I think you are misinterpreting what T is. Looking at these steps:
If you look at the water term, 5 is not the temperature in Kelvin of the water, it is the change in the water's temperature. The T in this equation plays the same role for the aluminum.
so should T actually be (Tf - Ti) where Tf is final temp and Ti is the initial temp? or should T just become deltaT = change in temp?
should i even have two unknowns for temperature?
actually it should have been 24.5 - 19 = 5.5, not 5. how do i use the temperature change (5.5)? am i supposed to find a temperature equivalent for 24.5 and 19? if so i don't know what scale the temperatures are in.
I don't think this is a very well worded problem. You need to make the assumption that both the water and the pan have reached thermal equilibrium. If that is the case then the pan would have the same final temperature as the water. Meaning that you only have one unknown (temp of pan).
i see what you're saying topher, so T should then be (24.5 - Ti)?
Yep.
is that the same case for the water, so instead of 5.5 it should also be T = (24.5 - Ti), what happens to the 19 degrees stated in the problem?
That shouldn't make a difference. 24.5 - Ti = 5.5.
Perhaps it would be clearer to re-write your energy balance:
[tex]m_{water} \cdot C_{water} \cdot (T_f - T_i)_{water}[/tex] + [tex]m_{AL} \cdot C_{AL} \cdot (T_f - T_i)_{AL} = 0[/tex]
Since they are in equilibrium, [tex] T_{f,water} = T_{f,AL} = T_f [/tex]
Plug that back into the equation above and the only unknown is [tex] T_{i,AL} [/tex], so it would then be a matter of rearranging the equation and plugging in the given/known values.
The initial and final temperatures were given in the problem in Celsius. Convert those to Kelvin before solving the equation (i.e. just add 273 to the given values). Also for future reference you may want to remember that Kelvin is an absolute scale. Hence, there can be no negative values in Kelvin.
Hope this helps.
CS
using the above equation i got this:
Tf_w = Tf_al = 24.5 = 24.5 + 273 = 297.5 kelvin
Ti_w = 19 = 19 + 273 = 292 kelvin
find Ti_al
[(12)(4184)(297.5-292)]_water + [(0.9)(900)(297.5 -Ti)]_aluminum = 0
271644 + 240975 - 810Ti = 0
810Ti = 517119
Ti = 638.41 kelvin, so for part one Ti in celsius = 638.41 - 273 = 365.418 celsius
and for part b using equation:
temp in fahrenheit = 9/5(365.418) + 32 = 689.753 deg fahrenheit
is that correct now?
sorry to double post, just wanted to let you all know that the above values i got were in fact correct.
thanks for the help
Related to Thermodynamics - hot item placed in water
What is thermodynamics?
Thermodynamics is the branch of physics that deals with the study of heat and its relationship with other forms of energy, including work and temperature.
What happens when a hot item is placed in water?
When a hot item is placed in water, heat energy is transferred from the hot item to the water. This causes an increase in the water's temperature and a decrease in the temperature of the hot item until they reach thermal equilibrium.
What is thermal equilibrium?
Thermal equilibrium is a state in which two objects at different temperatures are in contact with each other and there is no net transfer of heat energy between them. This means that the temperature of both objects remains constant.
How does thermodynamics apply to everyday life?
Thermodynamics plays a crucial role in everyday life, from the functioning of engines and refrigerators to cooking and heating our homes. It explains how energy is converted from one form to another and how heat is transferred, which is essential for many processes and technologies.
Why is thermodynamics important in science?
Thermodynamics is important in science because it provides a fundamental understanding of how energy works and how it is transferred between objects. It allows scientists to predict and analyze the behavior of systems, from microscopic particles to large-scale processes, and is essential in many fields such as chemistry, engineering, and environmental science.
9K
