aerograce
- 64
- 1
A piston‐cylinder initially contains 0.5 m3 of an ideal gas at 150 kPa and 20 degrees. The gas is suddenly subjected to a constant external pressure of 400 kPa and it is compressed in a manner that the final temperature is also 20oC. Assume the surroundings are also at 20 degrees. Take Cp=2.5 Ro. Determine:
(i) What is the entropychange of (a) the system,
(b) the surroundings and
(c) the universe or total?
(ii) Is the process reversible,irreversible or impossible?
U=Q-W;
S=Q/T;[/B]
For the system, because the temperature didn't change after compression.
Hence U=0;
Q=W;
W can be obtained by:
W=PV = 400KPa(V2-V1);
V2 can be obtained by using ideal gas equation;
PV= nRT;
However, I encounter difficulties in doing so because, if so, there is only one Q value, Q leaking out from the system = Q entering the surrounding. Hence the entropy will be zero instead, which is not right by the answer given.
The solution is given as follow and I don't really understand how they calculate the entropy change for system and equate it with isothermal process. And I doubt why the two Q values are different.
