Thermodynamics of a basaltic dike (dyke)
In summary, a user on a forum is seeking help with a research question regarding the formation of a 'chilled margin' on the edge of a basaltic dike. The user provides technical details and equations to describe the problem and proposes a solution involving thermal diffusivity and conductivity. They also mention potential complications with the surrounding rock's temperature.
hokulea
Hello,
Im newly registered to this forum, though I've been here from time to time, and have always enjoyed the level of guidance and general willingness of the forum members to help others. Now that I have an actual question, I figured it was time to sign up :)
Here is my problem, technically it's not homework or coursework, its a research question I am trying to work out, but I have no formal training in thermodynamics and could use some advice.
Basically, the question is this. I would like to determine the time it takes for a 'chilled margin' to form on the edge of a basaltic dike. The 'chilled margin' is a glassy portion on the outer part of the dike that comes into contact with the cooler country rock. As the country rock is no doubt much cooler than the intruding dike, a glassy layer forms. Now I am still working on determining the actual temperature values under which the glass can form (it is a range) and depends on the particular composition of the basalt I am studying. But to generalize let's just say that the glass forms between 1150 and 1100 C.
Now I have field measurements of these margins that range from 1cm to ~10cm, with the dike generally being about 1 m in total width. However, I am only considering the 1/2 width as there is another chilled margin on the other side of the dike.
So it seems to me that I can use the thermal diffusivity and conductivity, to describe the range of times that this margin took to form.
I have calculated the thermal diffusivity;
[tex]\alpha[/tex]= k/([tex]\rho[/tex]*K)
where k= thermal conductivity of basalt, 1.8 W/mK; [tex]\rho[/tex]= the mean density of basaltic glass, 2.772 kg/m^3; and K=degrees Kelvin
In this case the 'country rock' the dike has intruded is actually the volcano itself, so the composition and density are the same, and for these purposes I think I should ignore other heat transfer modes such as radiation, and convection. So basically, steady-state.
Please let me know if there is any relevant information that I have left out, and I really appreciate any advice given.
Ok, here is my stab at starting to solve this problem:
Problem (re-stated specifically for the following solution):
How long would it take to form a 'glassy or chilled margin' on a basaltic dike? The dike is initially molten at 1140 C and is solid at 880 C. Assume steady-state, 1 dimension.
Parameters:
Tl=temp. of liquidus=1140 C
Ts=temp. of solidus=880 Cp
ρ=density of basalt=2.772 g/cm^3
k=thermal conductivity=1.8 W/mC
Cp=specific heat= 1.05 J/gC
alpha=thermal diffusivity= k/(ρ*Cp)=6.1*10^-3 cm^2/s
Initial Condition:
T(x,0)= Ts for x0 < x < ∞
PDE:
∂T/∂t=alpha(∂^2 T)/(∂x^2 ) for x0 < x < ∞
Boundary Condition 1:
T(x0,t)= Tl for t>0
Boundary Condition 2:
T(x,t) ---> Ts as x ---> ∞ and t>0
Solution for T(x,t) is...
T(x,t)= Ts + (Tl - Ts) erfc[(x-x0)/(2√αt)]
where erfc(gamma)=1-erf(gamma)
(Im having trouble with typing equations here...)
Basically, I solved erf(gamma) for the temp. I was interested in 880 C, which came to gamma=3.2
T=880 + (1140-880)*(1-0.99999)=880
and then solved for x=10cm
x= gamma* 2(aplha*t)^1/2 => solving for t = x^2/(4*gamma^2*alpha) = ~400s
I hope this isn't too confusing, and I could really use some feedback. I think that 400s is pretty reasonable for bringing the temp. down from 1140 to 880, but I think I might need to set the problem up slightly differently as the rock surrounding the dike is probably much, much cooler, and also gaining heat as the dike is giving off heat. This would no doubt slow down the rate at which the margin would form.
FAQ: Thermodynamics of a basaltic dike (dyke)
What is a basaltic dike (dyke)?
A basaltic dike (or dyke) is a vertical or near-vertical intrusion of basaltic magma that cuts across the layers of surrounding rock. It is typically formed when molten basaltic magma is forced into a crack or fissure in the Earth's crust and solidifies as it cools and crystallizes.
How does the thermodynamics of a basaltic dike work?
The thermodynamics of a basaltic dike involves the study of the energy and heat transfer processes that occur during the formation, cooling, and solidification of the magma. This includes understanding the physical and chemical properties of the magma, such as its temperature, pressure, and composition, and how these factors influence its behavior and the resulting formation of the dike.
What factors influence the cooling and solidification of a basaltic dike?
The cooling and solidification of a basaltic dike is influenced by several factors, including the initial temperature and composition of the magma, the rate at which heat is transferred to the surrounding rock, and the size and shape of the dike. Other factors such as the presence of water or other minerals in the surrounding rock can also affect the cooling and solidification process.
How does the thermodynamics of a basaltic dike relate to geologic processes?
The thermodynamics of a basaltic dike is an important aspect of understanding geologic processes, as it provides insights into how magma intrusions can alter the composition and structure of the surrounding rock. By studying the thermodynamics of basaltic dikes, scientists can gain a better understanding of how dikes form, how they interact with surrounding rock, and how they can impact the formation of other geological features.
What are the practical applications of studying the thermodynamics of a basaltic dike?
Studying the thermodynamics of a basaltic dike has practical applications in a variety of fields, including geology, mining, and energy production. By understanding the thermodynamics of dikes, scientists can locate potential sources of valuable minerals and resources, and engineers can use this knowledge to design more efficient methods for extracting these resources. Additionally, understanding the thermodynamics of dikes can also help in predicting volcanic eruptions and assessing the potential hazards they may pose to nearby communities.
