Thermodynamics of exothermic reactions in hand warmers
In summary, there may be a contradiction between the chemical reaction and change of state explanations for hand warmer temperatures, but it's possible that the design of the hand warmer accounts for this discrepancy.
sfensphan
I was reading online about the reactions used in hand warmers. One website that their version always heats up to 54 C (http://www.heatinaclick.com/Default.asp?sType=0&PageId=81390). This one works by a supersaturated fluid of sodium acetate crystallizing. Other hand warmers work by oxidation of iron(2) to iron(3). This reaction is usually listed as an amount of energy released per kg or mole. Both are a reaction of some sort but there seems to be a contradiction here. How could a handwarmer guarantee a certain temeprature? If the chemicals in the handwarmer were really cold, couldn't the energy that is released be insufficient to raise it to a specific temperature. On the other hand, I remember in chemistry lab that a defining characteristic of a material is it's melting temperature, when it shifts from solid to liquid. Is there a contradiction here or is it because one is a chemical reaction and the other is a change of state that allows them to specify what temperature it occurs at?If it was really cold then the reaction would have to generate more energy than if it was really warm to achieve the 54 degrees. That seems to violate a principal.
My apologies if this is confusing. I am as well. Many thanks for your comments. I greatly appreciate your time and thoughts.
Science news on Phys.org
That's a great question! It's definitely confusing to think about how a hand warmer could guarantee a certain temperature while also having to produce more energy when it's colder out. One possibility is that, when the hand warmer is exposed to a colder environment, the reaction rate of the chemicals inside the hand warmer would increase, leading to a larger amount of energy being released and thus a higher temperature. The other possibility is that the hand warmer is designed to produce a constant amount of energy, regardless of the external temperature, meaning that when it's colder out, the energy is more concentrated in a smaller area and thus has a larger effect on the temperature. It's hard to say without knowing more information about the specific hand warmer, but those are two possibilities.
Related to Thermodynamics of exothermic reactions in hand warmers
1. What is an exothermic reaction?
An exothermic reaction is a chemical reaction that releases heat energy. This means that the reactants have a higher energy level than the products, and the excess energy is released in the form of heat.
2. How do hand warmers use exothermic reactions to generate heat?
Hand warmers typically contain a mixture of iron powder, activated carbon, salt, and water. When these materials come into contact, they undergo an exothermic reaction, producing heat as a byproduct. This heat is then trapped and released slowly, providing warmth for the hands.
3. What is the role of thermodynamics in hand warmers?
Thermodynamics is the study of energy and its transformations. In the case of hand warmers, thermodynamics helps us understand how the exothermic reaction produces heat and how that heat is transferred and stored in the hand warmer. It also helps us optimize the design and materials used in hand warmers for maximum efficiency.
4. Can the temperature of a hand warmer be controlled?
Yes, the temperature of a hand warmer can be controlled by adjusting the amount and ratio of the reactants used. For example, a hand warmer with a higher iron powder to water ratio will produce more heat, while a lower ratio will result in a lower temperature. The design of the hand warmer can also play a role in controlling the temperature.
5. Are hand warmers reusable?
Some hand warmers can be reused, while others are designed for one-time use only. Reusable hand warmers often use a reversible exothermic reaction, meaning the reaction can be reversed by adding heat, such as boiling the hand warmer in water. However, one-time use hand warmers are typically more cost-effective and easier to use.
  • Materials and Chemical Engineering
  • Thermodynamics
  • Other Physics Topics
