Thermodynamics Piston Cylinder Problem
In summary, the conversation discusses a problem involving a sample of gas in a piston cylinder arrangement and the determination of final pressure, volume, work transfer, heat transfer, thickness of the cylinder, and mass of the container. The solution involves using the ideal gas law and the polytropic process equation, as well as considering the given information and variables. It is also important to ensure consistency in units and to sketch a diagram of the system.
thorwynn
We were given a problem and asked to write a c++ program about this problem:
A sample of gas is inside a piston cylinder arrangement initially at a temperature of 303K. The gas is leaked to a final temperature of 323K. According to the process PV^n=constant. The cylinder is made of aluminum with dimensions of L=2D and with a uniform thickness T.
Input data (given):
1. User chooses the kind of gas (nitrogen,etc.)
2. mass of the gas, in kg.
3. polytropic index, n (1 to 3 only)
4. initial pressure, P1 (value from 1 to 3 bar only)
Find the following:
1. Final Pressure
2. Final Volume
3. Work Transfer
4. Heat Transfer
5. Thickness of cylinder
6. Mass of the container including the gas.
Can someone help me out on this, just giving me some points or equations on where to start will do. I am completely blank on this problem. Give me some tips on how to derive the right equation to be used in the problem. Thanks in advanced.
This is a closed polytropic system, so
P1(V1)ⁿ = P2(V2)ⁿ,
Using the ideal gas law: V2 = mRT2/P2, thus
P1(V1)ⁿ = P2(mRT2/P2)ⁿ = (P2)^(1-n) (mRT2)ⁿ,
(P2)^(1-n) = P1(V1/mRT2)ⁿ,
P2 = P1(V1/mRT2)^(n/1-n)
Where V1 = π(D²/4)2D,
V2 = mRT2/P2
W = (P2V2 – P1V1)/(n-1)
Q – W = ∆U
m(gas) is given.
m(cyl) = ρV= (2.6x10^-3)( π(D²/4 – (D-t)²/4)2D)
= 2.6x10^-3( π(D²/4 – (D-t)²/4)2D)
These are just some initial equations and steps that can be used to solve this problem. The first step is to identify the given information and variables, and then use the appropriate equations to solve for the unknowns. In this case, the ideal gas law and the polytropic process equation are the main equations that will be used. It is important to also consider the units of the given variables and ensure they are consistent throughout the calculations. Additionally, it may be helpful to sketch a diagram of the system to better visualize the problem and identify any other potential variables that may be needed. Good luck!
= 3.3x10^-2 kg
T1 = 303K, T2 = 323K
To start, we need to understand the given conditions and variables, as well as the equations and principles of thermodynamics that apply to this problem. The first principle of thermodynamics states that energy cannot be created or destroyed, only transferred or converted from one form to another. This is important to keep in mind when considering the work and heat transfer in this problem.
Next, we need to consider the ideal gas law, which relates the pressure, volume, and temperature of a gas. This law can be rearranged to solve for any of these variables, depending on what information is given.
In this problem, we are given the initial and final temperatures, as well as the initial pressure. We also know that the gas follows a polytropic process, meaning that the relationship between pressure and volume is described by the equation PV^n=constant. This equation can be used to find the final pressure and volume, as shown in the Attempt at a Solution above.
To find the work transfer, we can use the equation W = (P2V2 – P1V1)/(n-1), which is derived from the first law of thermodynamics and the ideal gas law. This equation takes into account the change in volume and the polytropic index.
To find the heat transfer, we can use the equation Q – W = ∆U, where Q is the heat transfer, W is the work transfer, and ∆U is the change in internal energy. In this problem, we are assuming that the system is adiabatic (no heat transfer), so the heat transfer would be equal to zero.
To find the thickness of the cylinder, we can use the equation for volume of a cylinder (V=πr²h) and solve for the thickness (h), using the known volume and diameter of the cylinder.
Lastly, to find the mass of the container including the gas, we can use the density of aluminum (ρ) and the volume of the cylinder to calculate the mass (m=ρV).
Overall, the key to solving this problem is understanding the principles of thermodynamics and how they apply to this specific situation. By carefully considering the given information and using the appropriate equations, we can solve for the desired variables and provide a complete response to the problem.
Related to Thermodynamics Piston Cylinder Problem
1. What is a thermodynamics piston cylinder problem?
A thermodynamics piston cylinder problem is a type of engineering problem that involves analyzing the behavior and properties of a gas or fluid within a piston-cylinder system. This system is commonly used in engines and other mechanical devices to convert heat energy into mechanical work.
2. What are the main components of a piston cylinder system?
The main components of a piston cylinder system include a piston, a cylinder, and a gas or fluid. The piston is a movable component that can compress or expand the gas or fluid within the cylinder. The cylinder is a closed container that holds the gas or fluid, and it may have a fixed or movable end. The gas or fluid inside the system is the working substance that undergoes changes in temperature and pressure.
3. How is the first law of thermodynamics applied to a piston cylinder problem?
The first law of thermodynamics, also known as the law of conservation of energy, states that energy cannot be created or destroyed, only transferred or converted. In a piston cylinder problem, this law is applied by considering the energy balance of the system, taking into account the heat transfer, work done, and change in internal energy of the gas or fluid.
4. What assumptions are typically made in solving a thermodynamics piston cylinder problem?
Some common assumptions made in solving a thermodynamics piston cylinder problem include: the gas or fluid is an ideal gas, the process is reversible, there is no heat transfer between the system and its surroundings, and there is no change in kinetic or potential energy of the system.
5. How can the efficiency of a piston cylinder system be calculated?
The efficiency of a piston cylinder system can be calculated by dividing the work output by the heat input. The work output can be determined by measuring the mechanical work done by the system, while the heat input can be calculated by measuring the heat added to the system or the change in internal energy of the gas or fluid.
10K
