Thermodynamics piston question
You're very close. First, to find the specific heat of air at constant volume, you can use the equation c=Q/m*deltaT. Since the initial volume is 0.425 m3, the volume remains constant and the process is isovolumetric. Therefore, Q=n*Cv*deltaT. Plugging in the given values, we get: c = (n*Cv*deltaT)/m c = (PV/RT * Cv * deltaT)/m c = (P*molar mass of air*deltaT)/(m*R*T)Since we are given the initial pressure and temperature, we can solve for n using the ideal gas equation. Then, we can solve
Denn
A vertical cylinder with a heavy piston contains air at 285 K. The initial pressure is 3.25 105 Pa, and the initial volume is 0.425 m3. Take the molar mass of air as 28.9 g/mol and assume
CV = 5/2R.
(a) Find the specific heat of air at constant volume in units of J/kg · °C.
J/kg · °C.
(b) Calculate the mass of the air in the cylinder.
kg
(c) Suppose the piston is held fixed. Find the energy input required to raise the temperature of the air to 675 K.
kJ
(d) Assume again the conditions of the initial state and assume the heavy piston is free to move. Find the energy input required to raise the temperature to 675 K.
kJ
So far I've identified ill need to use these equations:
-Q=m*C*deltaT
-c=Q/m*deltaT
-W=-P(Vf-Vi) (For a isobaric process)
-Q=n*Cv*deltaT (For a gas with constant volume)
-Q=n*Cp*deltaT (For a gas with constant pressure)
-PV=nRT
- Cp-Cv=R
To begin i equated the first and the second equation to recieve:
C=n*Cv/m
Mass is the unknown quantity and now I'm stuck.
If the piston is held in place then the volume is constant and the process is isovolumetric and therefore Eint=Q and does Q = n*Cv*deltaT?
If the piston is allowed to move freely then the process is isobaric and the Work = -P(Vf-Vi). Does Eint therefore = Q + W = n*Cp*deltaT - P(Vf-Vi) ?
Any help is greatly appreciated!
Thanks
CV = 5/2R.
J/kg · °C.
kg
kJ
kJ
-Q=m*C*deltaT
-c=Q/m*deltaT
-PV=nRT
- Cp-Cv=R
C=n*Cv/m
Is the initial pressure supposed to be 325 KPa?
You can calculate the mass from the number of moles, n. You can determine n simply by using the ideal gas equation: n = PV/RT
Yes. Isochoric = constant volume.
If P is constant, the heat flow is: [itex]\Delta Q = nC_p\Delta T[/itex]. This takes into account the work that is done since Cp = Cv+R and PdV = nRdT. So in applying the first law for isobaric process:
[tex]\Delta Q = \Delta U + P\Delta V = nC_v\Delta T + nR\Delta T= n(C_v+R)\Delta T = nC_p\Delta T[/tex]
AM
Related to Thermodynamics piston question
1. What is the purpose of a piston in thermodynamics?
A piston is a component used in thermodynamics to convert the pressure of a gas into mechanical work. It is typically a cylindrical object that moves back and forth within a cylinder and is used to control the volume of the gas, thereby changing its pressure.
2. How does a piston work in a thermodynamic system?
A piston works by moving back and forth within a cylinder in response to changes in pressure. When the pressure of the gas inside the cylinder increases, the piston moves outward, and when the pressure decreases, the piston moves inward. This movement can be harnessed to perform work.
3. What is the relationship between a piston and the ideal gas law?
The ideal gas law, which states that the pressure of a gas is directly proportional to its temperature and number of moles, is directly related to the movement of a piston. As the temperature and number of moles of gas remain constant, a change in pressure will result in a corresponding change in the volume of the gas and the position of the piston.
4. Can a piston be used to create a perpetual motion machine?
No, a piston cannot be used to create a perpetual motion machine. This is because thermodynamics laws, specifically the first and second laws, state that energy cannot be created or destroyed and that the overall entropy of a closed system will always increase or remain constant. Therefore, a piston cannot continuously perform work without an external energy source.
5. How is a piston used to measure the work done in a thermodynamic process?
A piston can be used to measure the work done in a thermodynamic process by attaching a pressure gauge to the cylinder. As the piston moves, the pressure of the gas can be measured at different points, and the work can be calculated using the formula W = PΔV, where W is the work, P is the pressure, and ΔV is the change in volume.
  • Classical Physics
9K
