Thermodynamics polytropic processes and work for them
In summary: The results may not be the same because the two calculations are for different types of systems. In a control volume, there is a net flow of energy and matter, while in a closed system, there is no flow of energy or matter. Therefore, the equations for calculating work are different.
mihalj
Hi, something is a bit confusing in regards to polytropic processes.Can anyone explain why boundary work in closed system for compressor is calculated as W = ∫pdV and polytropic process after integration is generally W = -(p2V2 - p1V1)/(1-n)...(numbers behind p and V are subscripts)...
When we talk about control volume, internally reversible process (isn't above one also reversible?) then work is defined as W = -∫Vdp and for polytropic process for compressor work is defined as W = -n*(p2V2-p1V1)/(n-1).
When I am supposed to use one way of calculation and when other? The results are not same. Aren't they same type of group as control volume compressor should behave during the process of compression as closed system (there is no constant add or removal of mass during compression).
Thanks in advance!
A:A polytropic process is a thermodynamic process in which the pressure $P$ of a gas varies linearly with its volume $V$, while its temperature remains constant. The work performed by a polytropic process on the system, with initial and final pressures $P_1$ and $P_2$ respectively, and initial and final volumes $V_1$ and $V_2$ respectively, is given by $$ W=-\frac{n}{n-1}\left(P_2V_2-P_1V_1\right)$$ where the polytropic index $n$ is a measure of how closely the polytropic process approximates an isothermal process; it is a property of the thermodynamic system.For a closed system, the work is calculated as $$W=\int_{V_1}^{V_2}P \mathrm{d}V$$For a control volume, where there is a net flow of energy and matter into and out of the system, the work is calculated as $$W=-\int_{V_1}^{V_2}V \mathrm{d}P$$Note that these equations are derived from the first law of thermodynamics, which states that the change in the internal energy of a system is equal to the sum of the heat added to the system and the work done on the system.
FAQ: Thermodynamics polytropic processes and work for them
1. What is a polytropic process in thermodynamics?
A polytropic process is a type of thermodynamic process in which the relationship between pressure and volume can be expressed as P*Vn = constant. This means that the process follows a specific power law, with n being the polytropic index.
2. How is work calculated in a polytropic process?
The work done in a polytropic process can be calculated using the formula W = (P2V2 - P1V1) / (1-n), where P1 and P2 are the initial and final pressures, and V1 and V2 are the initial and final volumes, respectively.
3. What is the significance of the polytropic index in a thermodynamic process?
The polytropic index, n, represents the type of process being followed. A value of n=1 represents an isothermal process, n=0 represents an isobaric process, and n=infinity represents an isochoric process. Intermediate values of n represent polytropic processes.
4. How does a polytropic process differ from an adiabatic process in thermodynamics?
A polytropic process allows for heat exchange with the surroundings, while an adiabatic process does not. This means that in a polytropic process, the temperature can change, while in an adiabatic process, the temperature remains constant.
5. What are some real-world applications of polytropic processes in thermodynamics?
Polytropic processes are commonly observed in gas turbines, air compressors, and refrigeration systems. They are also used in the analysis of chemical reactions and in the design of heat exchangers.
28K
15K
