Thermodynamics problem -Does this approach seem right?
In summary, the equilibrium state of a dilute gas consisting of N hydrogen atoms at temperature T and pressure P involves a fraction of the atoms combining to form diatomic hydrogen molecules. The free energy of the system is given by a formula involving the number of single atoms (Ns), the number of diatomic molecules (Nd), and other parameters. To find the relation between Ns and Nd in equilibrium, we need to minimize the free energy formula by setting its derivative equal to zero. This leads to the equation 2Nd + Ns = N, which shows the total number of atoms (N) is divided between single atoms and diatomic molecules.
TroyElliott
59
A dilute gas consisting of N hydrogen atoms in equilibrium at temperature T and pressure P. A fraction of the atoms combine to form diatomic hydrogen. For ##N_{s}## single atoms and ##N_{d}## diatomic molecules, the free energy of the system is
$$G = N_{s}k_{b}T\ln{(\frac{N_{s}}{N_{s}+N_{d}}\frac{P}{P^{0}_{s}})}+N_{d}k_{b}T\ln{(\frac{N_{d}}{N_{s}+N_{d}}\frac{P}{P^{0}_{d}})} - \epsilon N_{d}.$$
Here ##\epsilon## is the binding energy of the ##H_{2}## molecule, and ##P^{0}_{s}## and ##P^{0}_{d}## are functions of only temperature. Find the relation between ##N_{s}## and ##N_{d}## in equilibrium.
##\Delta G = 0##
##G_{initial} = N_{s}k_{b}T\ln{(\frac{P}{P^{0}_{s}})}?##
##\Delta G = G_{final}-G_{initial} = 0.## I assume that the ##G_{final}## is the formula for the free energy given in the problem statement. Is it right to assume that ##G_{initial}## is given by setting ##N_{d}## to zero? I am assuming that initially all the hydrogen was just made up of single atoms and the free energy formula above would still be valid for this. Does this seem like the right approach? The algebra gets messy and I haven't been able to get a clean relationship between ##N_{s}## and ##N_{d}##.
Thanks!
No. I don't agree with your approach. You have that, in any state, $$2N_d+N_s=N$$ You need to find the value of ##N_s## that minimizes G.
Related to Thermodynamics problem -Does this approach seem right?
1. What is thermodynamics and why is it important?
Thermodynamics is the branch of physics that deals with the relationship between heat, work, and energy. It is important because it helps us understand and predict how energy is transformed and transferred in various systems, such as engines, refrigerators, and chemical reactions.
2. How do you approach solving a thermodynamics problem?
The first step is to clearly define the system and its boundaries. Then, identify the known and unknown variables and determine which thermodynamic laws and equations are applicable. Next, use algebraic manipulation and substitution to solve for the unknown variables. Finally, check your solution for accuracy and units.
3. What are the common pitfalls when solving a thermodynamics problem?
One common pitfall is not properly defining the system and its boundaries, which can lead to incorrect assumptions and solutions. Another pitfall is not considering all relevant thermodynamic laws and equations, leading to an incomplete or incorrect solution. It is also important to pay attention to units and conversions, as they can greatly affect the final answer.
4. How do you know if your approach to a thermodynamics problem is correct?
A good way to check if your approach is correct is to see if your solution satisfies the laws of thermodynamics, such as conservation of energy. Additionally, you can compare your solution to known values or use estimation techniques to see if your answer is reasonable. It is also helpful to double check your calculations and units.
5. Are there any tips for solving thermodynamics problems more efficiently?
One tip is to draw a clear and accurate diagram of the system, as it can help visualize the problem and identify key variables. It is also helpful to break down the problem into smaller, more manageable steps. Additionally, using standard thermodynamic tables and equations can save time and reduce the chance of errors. Lastly, practice and familiarize yourself with different types of thermodynamics problems to improve efficiency.
  • Quantum Physics
