Thermodynamics problem - Find the kinetic energy of ideal gas, given P and V
To find the kinetic energy of an ideal gas with a volume of 10 liters and pressure of 5·10^5, the relevant equations are p·V = N·k·T and Ek = 2/3 k·T·N. The discussion clarifies that the average kinetic energy per molecule (Ek) relates to the total kinetic energy of the gas (N·Ek). A key point is that Ek can be derived directly as Ek = 2/3 p·V, confirming the connection between pressure, volume, and kinetic energy. The participants emphasize the importance of distinguishing between average kinetic energy per molecule and total kinetic energy.
arddi2007
Find the Kinetic Energy of the ideal gas \overline{Ek}=? if its volume is 10 liters (10-2 m3) and it is under the pressure of p=5·105.
p·V = N·k·T (where p-pressure, V-volume, N-number of particles (molecules), k- Boltzmann constant, T-absolute temperature (in Kelvins))
Ek=Mm·\overline{v}2/2 (where Mm-the mass of the molecule and \overline{v}-the quadratic velocity of the molecule)
Ek=3/2 k·T (where k-the Boltzmann constant and Ek - kinetic energy (of the ideal gas in this case))
With the help of Wikipedia, I was really close to solving this one. But at the end I got a little confused and now I need help. This is my progress:
p·V=N·k·T
p= N·k·T/V
p=N/V · 2/3 Ek
p·V = 2/3 N · Ek
Knowing that Ek=Mm·\overline{v}2/2 :
p·V= 2/3 · N · Mm·\overline{v}2/2
Since p·V=N·k·T:
N·k·T=N·Mm·\overline{v}2/3
then: T= Mm·\overline{v}2/3·k
This is the part when it gets tricky. I assumed that since Ek=2/3 k·T, it would be that:
T=2/3 Ek/k
and then we would substitute T in p·V=N·k·T. But it Wikipedia it says that Ek=2/3 k·T·N. Can anyone confirm that and tell me where that equation was derived from?
I really need to solve this equation. As you can see, I nearly solved it but I just need a small push. I really need to get this done by tonight so any help at all would be greatly appreciated. Thank you very much for your time!
p·V=N·k·T
p= N·k·T/V
p=N/V · 2/3 Ek
p·V = 2/3 N · Ek
OK. Looks to me like you're just about done. Note that Ek is the average KE per molecule so N · Ek would be the total KE of the gas.
hi arddi2007! :smile:
… Wikipedia it says that Ek=2/3 k·T·N. Can anyone confirm that and tell me where that equation was derived from?
i don't remember this stuff well,
but if p·V = N·k·T and Ek=2/3 k·T·N, doesn't that immediately give you Ek = 2/3 p·V ?
Thank you, I just needed the confirmation. So, all that is left to do is to substitute and from there we get:
Ek = 2/3 p·V
The part that I did not get was that Ek is the average KE per molecule, while the total KE of the gas is N·Ek. Thank you both very much!
Just an addendum to my last post:
Must be a typo. Ek = 3/2 kT.
Really?
Ek = 2/3 p·V
Careful with that.
Right!
Thank you very much for the heads up. I normally wouldn't make that mistake on my notebook but it's sometimes hard to focus when typing it.
By the way, I checked with my professor and he confirmed the solution is correct. Thank you all so much!
  • · Replies 30 ·
