Thermodynamics Problem involving an ideal gas Helium?
In summary, the conversation discusses a physics problem involving a helium gas undergoing isobaric expansion. The conversation covers questions about the final temperature of the gas, the work done by the gas, the heat input into the gas, and the change in thermal energy of the gas. The solution to part a) is found using the ideal gas law, while the solution to part b) is still being worked on. The correct values for the final temperature, work done, heat input, and change in thermal energy are provided.
hbk69
81
Hi guys i am new here hope you are all well, had a problem with a physics question hope you can help.
Helium gas m=2.0(g) is at an initial temperature T1=100 degreees and initial pressure P1=100000 Pa, and has a volume V1. The gas undergoes isobaric (P=constant) expansion until its volume is doubled V2= 2V1. Molar Specific Heat at constant pressure for Helicum Cp=2.08 J/mol K
a)Final temperature of the gas?
b)work done by the gas?
c)the heat input Q into the gas?
d)What is the change in the thermal energy of the gas (change in E (th) ) ?
I attempted part a) but i didnt know how i could find the Heat Energy Q needed to change the tempeartue of the ideal gas at constant pressure and i did not know how i could find the number of moles (n) for helium either i know the atomic mass from the periodic table but how to i work out the mass of helium? because n=mass/molar mass, these factors prevented me from applying the formula Q=n*Cp*(Change in T), Could you be specific when showing me the method i need to apply, as my understanding of physics and maths is weak.
Thank you, very much appreciated
You wrote "Helium gas m = 2.0 (g) ...". If that is not he mass, then what is that?
Anyway, you do not need anything of the above to solve a). You need to recall how temperature and volume are related in an isobaric process. If you can't recall, use the ideal gas to relate them.
You know the atomic mass of helium from the Periodic Table, M=4g. You know that the helium gas consists of single helium atoms. You know the mass of the helium gas in the vessel: m=2g. So what is n?
ehild
Here is some equations maybe useful for your problem.
To find:
1. the Q, just use the Q=mc∆T
2. the final temp, use P1.V1/T1=P2.V2/T2
3. the work done, use Q=∆U+w
4. the mole(n), use n=mass/Molarmass or PV=nRT
just apply it :)
I already try found it that for,
a) the final temperature is 200 degree (don't know whether it is in K or C)
b)W=415.7 J (another equation, W=P∆V)
c)Q=0.416 J
for d) I'm not really understand about the question.
is it correct? do u have the answer key to check it or not?
Sorry guys i made an error, yes the mass is 2.0g and i am able to work out the number of moles
c)Q=0.416 J
all of them are wrong, these are the answers:
a)746K
b)1550K
c)3879K
d2329J
For part a) i now neeed Q but how can i find it if i don't know the specific heat capacity of helium?
Have you read the statement of the problem?
(which, by the way, is not the correct number)
And as voko said, you don't even need the heat capacity. You can use the ideal gas law instead.
Okay thanks, sorryi was mistaking the Cp for "c", am going to work it out now and see if i get the correct answer.
for part a) The final temperature Tf= Q/n*Cp+T1 gave me the correct answer and you were correct the Cp was 20.8 made a typo error.
c)Q=0.416 J
I can't work out the work done for part b)? i tried using re arranging PV=nRT to get the volume so i could put it in W=PV but didnt get the correct answer, how did you get the value for volume? and i don't understand the formula Q=U+w, if w is the work and Q what i had worked out from part a) what is "U" thanks
It's the right way. Please show your calculation if you want some help.
##U## is the total energy of the system. Be careful, because there are different conventions for the sign of ##W##. ##U=Q-W## is simply an expression of the first law of thermodynamics.
V=nRT, i think i made a mistake with the temperature. 4.997x10^-4(n)*8.31(R)*T/1.1x10^5(P)
Then i put the answer in W=PV
(For T i used the 747K as well as the T1 which was given in the problem but still never got the correct answer)
How would it be possible to use U=Q-W when i don't know what the total energy of the system is, thanks for your help again
what is the error in my calculation? and did i use the correct value for T? thank you
Your problem is with ##n##.
Sorry, the equation should be ##dU = Q - W##. We are considering the change in energy.
For a monatomic ideal gas, ##U## includes only kinetic energy (no nuclear, electronic, gravitational, etc., energy), so you can even calculate it exactly using
U = \frac{3}{2} n R T
(You can also calculate it for ideal gases that are not monatomic, but I don't want to go into the details now.)
how can "n"be wrong if it gave me the correct value for part a)? if it is how can i get the correct value please
n = \frac{m}{M} = \frac{2\ \mathrm{g}}{4\ \mathrm{g\,mol}^{-1}} = 0.5\ \mathrm{mol}
I got part a) by using the other ideal gas equation PV/T(initial)=PV/T(final), while for V1 I got it from the other PV=nRT equation. After I got the V1, then I used the W=P∆V to find the W. Btw the ∆U is the internal energy, the sum of all K.E of the molecule, this is used at Q=∆U+W (the first law of thermodynamics).
Btw DrClaude and hbk69, did you change the temperature into Kelvin? Because I'm not convert the 100 degrees because there is no unit provided.
I just try it again by convert the 100 degrees (found that it is in C) into Kelvin which is 373 K, convert the 100000 Pa into 100 kPa.
part a), using the PV/T(initial)=PV/T(final):
100(V1)/373 = 100(2V1)/Tf
(100 and V1 cancels out)
Tf=373(2)
Tf=746 K
part b), using PV=nRT
100V1=(2/4) x 8.314 x 373
V1=15.5 dm^3
Then, use the W=P∆V
W=100x15.5
W=1550J
for part c) & d) I'm still trying to find it,
For part c) by using the equation gave by DrClaude U=3/2(nRT)
U=3/2(0.5 x 8.314 x 373)
U=2326 J
then, by using Q=∆U+W
Q=2326 + 1550
Q=3876 J
For part d) the change in thermal energy of the gas is the same as ∆U which is 2326 J
*the difference between 2329 J and 2326 J maybe because of the calculator.
Yes bs15benny it was in 100 degrees C, also in your calculation for part a) why is P2 also 100k Pa? and why is it that when i calculated Tf via Q=n*Cp*T i had to convert the mass 2.0g to kilograms before i got the number of moles where as when i am supposed to work out the work done by the idea gas in part b) i leave the mass as it is when working out the number of moles, its something to do with the units as they cancel each other out as DrClaude showed in post 17 but don't understand why n is different for part a) and part b) but know how to get the answers nevertheless.
Just on part c) and d) to, the corred answers are:
c)3879J
d2329J
Trying to do them.
Thank you very much guys for your help! i understand how to calculate the problems, the only issue i have is with the different values of "n" for part a) and b) as well as P1=P2 (which could be because of the ideal gas law?) and exactly what "U" is, does it also include potential energy of the ideal gas and any other form of energy?
the mass 2g I converted it into 0.002 kg for Q=mc∆T but for mole, I still used the mass in gram. While P2 also 100 kPa because the question said that the pressure is the same (constant) in this case is isobaric. For U the other type of energies cannot be included because it is only the sum of all K.E (in the gas, the molecules vibrating which is K.E not P.E).
For part c) and d), I think my answer is still acceptable maybe it is because the value of R that I used is 8.314
Related to Thermodynamics Problem involving an ideal gas Helium?
1. What is an ideal gas in thermodynamics?
An ideal gas is a theoretical gas that follows the ideal gas law, which states that the pressure of a gas is directly proportional to its temperature and the amount of gas present, and inversely proportional to its volume. It also assumes that the gas particles have no volume and do not interact with each other.
2. How is helium used in thermodynamics problems?
Helium is often used as an ideal gas in thermodynamics problems because it is a light and monoatomic gas, which means it behaves closely to the assumptions of an ideal gas. It also has a low boiling point and does not easily liquefy, making it easier to work with in experiments.
3. What is the ideal gas law and how is it used in thermodynamics?
The ideal gas law, also known as the general gas equation, is PV=nRT, where P is pressure, V is volume, n is the number of moles, R is the gas constant, and T is temperature. It is used in thermodynamics to calculate the relationships between these variables in an ideal gas system.
4. How does temperature affect the behavior of helium in thermodynamics?
According to the ideal gas law, temperature and pressure are directly proportional. This means that as temperature increases, the pressure of the helium gas will also increase. Additionally, as the temperature decreases, the volume of the gas will decrease as well.
5. Can the ideal gas law be applied to real gases?
The ideal gas law is a simplified model that applies to ideal gases. In reality, most gases do not behave exactly like an ideal gas, especially at high pressures and low temperatures. However, in many cases, the ideal gas law can still be used as an approximation for real gases, as long as the conditions are not too extreme.
