Thermodynamics - Question with my answer
In summary: If heat flows into the system then the internal energy will increase. Conversely if heat flows out of the system then the internal energy will decrease.In summary, a gas is compressed from an initial volume of 5.40 L to a final volume of 1.23 L by an external pressure of 1.00 atm. During the compression, the gas releases 128 J of heat. The work done on the gas is 422.5 J, and the internal energy of the gas increases by 294.5 J. The negative work done means that the gas is receiving energy from an external source, while the negative heat flow means that the gas is losing energy. Overall, the internal energy of the gas increases due to the positive
manal950
177
A gas is compressed from an initial volume of 5.40 L to a final volume of 1.23 L by an external pressure of 1.00 atm . During the compression the gas releases 128 J of heat.
My answer :
given data :
v1 = 5.40 l
v2 = 1.23 l
P1 - 1.00
now convert L to m^3 and atm to pa so
1 l =0.001 cubic meters
1 atm = 101,325 pa
v1 = 5.4X10^-3 m^3
v2 = 1.23 X 10^-3 m^3
p = 101325 pa
now DU = -Q - W
w = -pXDv = 101325(1.23 X 10^-3 - 5.4X10^-3 )
w = 422.5 J
now DU = -Q + W
= -128 + 422.5
Du = 294.5 J
W = p ΔV
= - 423 J
The negative work being done means that it is receiving energy from an external source (doing work on it)
Q = -128 J
The negative means that it is losing energy (heat)
so that from
ΔU = Q - W
= -128 -(-423)
= 295 J
the internal energy increased by this amount
thanks, but how we can no from the question that the system receiving energy from an external source ...?
Work and energy go hand in hand. The system will loose energy if it is doing positive work and gain energy if it is doing negative work. It is doing positive work if it is expanding, since it is exerting an outwards force against the atmosphere while expanding, negative work if contracting, since the system is still exerting an outwards force on the atmosphere, but now it is motioning in the opposite direction to the force, that is contracting inwards. Also if ΔU is positive then we have a net energy flow into the system. We also need to consider the heat flow, which is a form of energy.
Therefore, the change in internal energy of the gas during compression is 294.5 J. This indicates that the gas has gained energy from its surroundings and has done work on the surroundings as it was compressed. This is in accordance with the first law of thermodynamics, which states that energy cannot be created or destroyed, only transferred from one form to another. In this case, the gas released heat energy and converted it into work energy.
Related to Thermodynamics - Question with my answer
1. What is thermodynamics?
Thermodynamics is the branch of physics that deals with the study of energy and its transformations, particularly in relation to heat and work. It is concerned with how energy is transferred between different forms and how it affects the properties of matter.
2. What are the laws of thermodynamics?
The laws of thermodynamics are fundamental principles that govern energy and its transformations. The first law states that energy cannot be created or destroyed, only transferred or converted from one form to another. The second law states that the total entropy of a closed system will always increase over time. The third law states that the entropy of a perfect crystal at absolute zero temperature is zero.
3. How is thermodynamics used in everyday life?
Thermodynamics has many practical applications in everyday life. For example, it is used in the design of engines, refrigerators, air conditioners, and other heat-based technologies. It is also important in understanding the energy processes that occur in the human body and in various chemical reactions.
4. What is the difference between heat and temperature in thermodynamics?
In thermodynamics, heat refers to the transfer of thermal energy between two bodies due to a temperature difference. Temperature, on the other hand, is a measure of the average kinetic energy of the particles in a substance. While heat is a form of energy, temperature is a measure of the intensity of heat.
5. Why is thermodynamics important in understanding climate change?
Thermodynamics plays a crucial role in understanding climate change as it governs the transfer and transformation of heat energy in the Earth's atmosphere. The increased levels of greenhouse gases, such as carbon dioxide, trap more heat in the atmosphere and contribute to the Earth's rising temperatures, making thermodynamics an essential tool in studying and addressing climate change.
